30-08-2007, 12:11 PM #1
Window AC - "Squeak" Noise when compressor turns off
Hello all,
A friend of mine directed me to this forum for some advice. I just purchased a LG LWHD8000R Window air conditioner last week, and I noticed that occasionally the unit makes a "squeak" or almost whistling noise when the compressor turns off. It almost sounds like pressurized or compressed air being released. It only does this very briefly and only after the compressor turns off during normal use. I picked up a second unit of the same model, tested it, and noticed that it does the same thing. Is this normal or something I should be concerned about? The unit is cooling very well - for now, at least. As the unit is quite new, I can still return it easily if necessary. Thanks.
John
30-08-2007, 01:17 PM #2
30-08-2007, 01:23 PM #3
Re: Window AC - "Squeak" Noise when compressor turns off
Lg squeak noise, hmm... it's probably the little mouse on his bicycle out of breath, you should...........(I appologise for that. It was just tooo tempting).
If it's like a hissing sound it will just be pressure equalizing between the high and low pressure sides of the system across the expansion device when the compressor shuts down. Nothing to worry about.Last edited by expat; 30-08-2007 at 01:24 PM. Reason: spelling
30-08-2007, 05:56 PM #4
Sounds good guys. Thank you for the replies.
noise pollution
By superswill in forum Legal-Business-MarketingReplies: 20Last Post: 06-11-2007, 01:14 PM -
noise inverter compressor
By Airclima in forum Air ConditioningReplies: 1Last Post: 26-07-2007, 11:42 PM -
Abnormal noise from compressor
By mano in forum Trouble ShootingReplies: 1Last Post: 09-02-2007, 11:21 PM -
Noise Levels
By Daddy Cool in forum Tools and CalculatorsReplies: 15Last Post: 07-04-2005, 02:21 PM -
Are all 8000BTU Window AC created equal?
By pwanghk in forum FundamentalsReplies: 20Last Post: 15-05-2002, 06:40 AM
