Thread: bakery walk in
30-08-2007, 02:23 AM #1
bakery walk in
have a customer with an 18 X 26 walk in, product is drying out, too wide TD? what should be the equipment to keep this area at 38 deg f. and proper TD
30-08-2007, 08:45 AM #2
Re: bakery walk in
I take it then that it is just a storage fridge.
Has it worked up to now and only just started to fail or is it a new install or old fridge that has never worked.
I'm sure I'll be corrected on this but in my opinion there are three ways to control the TD over the evap.
1 the correct design and sizeing of the system in the first place.
2 Control by electronic means (fan speed and such like)
3 Control by mechanical means (evaporator preasure regulators and such like)
Did the system work and is only now playing up? if so what has changed?
Has the system never worked? so needs some serious looking at?
Or is it a new system that is not performing well?
Cheers taz.Last edited by taz24; 30-08-2007 at 08:47 AM.
30-08-2007, 09:41 AM #3
Re: bakery walk in
What's the desired temp and humidity?
Whats the actual temp and humidity?
what type of product is stored, how is it stored (open, wrapped etc), and for how long?
What is the evap coil surface area size?
Heat load?
Refrigerant type, pressure and what's the TD?
walk in cooler EVAPORATOR coil icing up
By kurt854 in forum FundamentalsReplies: 5Last Post: 14-06-2007, 07:28 PM -
Need Help Sizing New Unit For Walk In
By refermadness in forum FundamentalsReplies: 5Last Post: 15-08-2006, 02:14 PM -
walk in Chiller--website
By nik in forum FundamentalsReplies: 9Last Post: 23-06-2006, 07:46 AM -
walk in Chiller--design
By nik in forum FundamentalsReplies: 4Last Post: 23-06-2006, 01:39 AM -
Walk in freezer with no LLS
By eskimo joe in forum FundamentalsReplies: 5Last Post: 07-05-2002, 06:35 PM
