    andy_lanc's Avatar
    andy_lanc Guest
    Question Is my FF beyond repair
    Hi, my integrated FF appears to have a small crack in the white inside. There is a build up of pressure in the white plastic that appears to have swolen the plastic. The fridge is not working but the freezer is fine. When I press the white plastic it sounds like gas is escaping from the crack into the fridge and there is a funny (presume gas-like) smell. Any ideas anyone? Many thanks! Andy.
    Oct 2006
    1,843
    Re: Is my FF beyond repair
    Quote Originally Posted by andy_lanc View Post
    If its a normal fridge freezer when the fridge fails to pull down to temp it normally indicates a major problem with the comp not pumping correctly or system short of gas.
    From what you have described it does sound like SOG.
    If thats the case then you would find it cheaper to replace than repair.
    Cheers taz.
    Aug 2007
    dubai united arab emirates
    63
    14
    agree with taz, better change than do the repair where you are also not sure of the outcome.
    final say is yours..
    andy_lanc's Avatar
    andy_lanc Guest
    Angry Re: Is my FF beyond repair
    many thanks! Looks like I'll be on the net this afternoon looking for a new one. Grrrr. Andy!
  1. VMY 347 repair manual
    By fassi in forum Refrigeration Books
    Last Post: 08-11-2007, 02:08 AM
  2. published repair times
    By thermo690 in forum Transport
    Last Post: 20-08-2007, 11:16 AM
  3. Repair Coplametic 6RA4 discharge valves
    By bvis in forum Fundamentals
    Last Post: 15-04-2007, 08:07 AM
  4. Repair of screws
    By reggie in forum Industrial Compressors
    Last Post: 04-08-2003, 05:26 PM
