Thread: Is my FF beyond repair
28-08-2007, 08:27 AM #1
Hi, my integrated FF appears to have a small crack in the white inside. There is a build up of pressure in the white plastic that appears to have swolen the plastic. The fridge is not working but the freezer is fine. When I press the white plastic it sounds like gas is escaping from the crack into the fridge and there is a funny (presume gas-like) smell. Any ideas anyone? Many thanks! Andy.
28-08-2007, 01:20 PM #2
Re: Is my FF beyond repair
If its a normal fridge freezer when the fridge fails to pull down to temp it normally indicates a major problem with the comp not pumping correctly or system short of gas.
From what you have described it does sound like SOG.
If thats the case then you would find it cheaper to replace than repair.
Cheers taz.
28-08-2007, 01:27 PM #3
agree with taz, better change than do the repair where you are also not sure of the outcome.
final say is yours..Last edited by nestor_greg1220; 28-08-2007 at 01:28 PM. Reason: wrong spelling
28-08-2007, 01:53 PM #4
many thanks! Looks like I'll be on the net this afternoon looking for a new one. Grrrr. Andy!
VMY 347 repair manual
By fassi in forum Refrigeration BooksReplies: 9Last Post: 08-11-2007, 02:08 AM -
published repair times
By thermo690 in forum TransportReplies: 2Last Post: 20-08-2007, 11:16 AM -
Repair Coplametic 6RA4 discharge valves
By bvis in forum FundamentalsReplies: 4Last Post: 15-04-2007, 08:07 AM -
Repair of screws
By reggie in forum Industrial CompressorsReplies: 6Last Post: 04-08-2003, 05:26 PM
