Results 1 to 8 of 8
Thread: toshiba fault codes
27-08-2007, 08:48 PM #1
toshiba fault codes
Hi Just found out about this site and wondered if anyone has any info on toshiba a/c fault code
COOLBOB
27-08-2007, 08:51 PM #2
Re: toshiba fault codes
Yup, got the techie book on DI and SDI kit if that would be of any help..
Karl
27-08-2007, 09:48 PM #3
I Have a Toshiba fault code list, unfortunatly its fairly old and dont have it on my computer. If you PM me with a phone number i can try and fax it through
Fatboy
31-08-2007, 12:23 AM #4
make extra sure that the condensing unit and the evap unit match in tonnage, or they wont communicate!
31-08-2007, 12:44 AM #5
Ha! I had an issue of a couple of Toshes not communicating properly.. Both would start up ok but after a while the slave unit would shut down and not run again untill I switched the system off and then on again (No apparent reason).. I threatend it with the same monkey wrench that I beat the crap out of an LG unit with... They seem to be working fine now....NOW THAT'S communication
By the way isitfixedyet, why is that girl showing you her contact lens?? Just curiousKarl
31-08-2007, 09:33 PM #6
Also try the Toshiba websites or even better try AMP here
http://www.ampair.co.uk/AMP%20Air%20...0Downloads.htm
Click on the Technical Handboook Version 10; it has the fault codes for RAS, RAV and upwards.Brian - Newton Abbot, Devon, UK
01-09-2007, 07:33 PM #7
http://www.dolphin-airco.be/documentatie.html
i find very helpfull
paulPaul
"KEEP IT COOL"
09-12-2007, 08:18 AM #8
Thankyou... Very helpful.
Regards,
Toshiba Fault codes
By bernard in forum Air ConditioningReplies: 28Last Post: 03-08-2010, 11:09 AM -
carrier fault codes
By richelli in forum Trouble ShootingReplies: 5Last Post: 18-06-2010, 07:35 AM -
Daikin fault codes
By Markie in forum Air ConditioningReplies: 16Last Post: 13-01-2009, 01:58 AM -
Toshiba a/c fault codes
By Latte in forum Air ConditioningReplies: 3Last Post: 27-09-2007, 09:33 PM -
MHI, Sanyo & Fuijitsu Complete Fault Codes
By aeb200 in forum Air ConditioningReplies: 1Last Post: 16-11-2005, 01:11 PM
