    Dec 2004
    Weihai,China
    800
    VRV vs air heat pump
    Hi Sirs
    One 150m2 villa need air conditioning all the year. There're VRV system and normal heat pump +FCU (heating and cooling) can be used for it. The initial cost VRV is at least 50% higher than normal air cooled hp but it's no problem with freezing issue in winter.
    If I select to use normal hp ,what is the best way to protect water pipe not freezing in winter season?
    Thanks for your input.
    best regards
    LC
    Moscow
    40
    82
    Re: VRV vs air heat pump
    Hi, Lc shi. You may use glycol (if it is possible) or insulate the tubes. But I think that VRV is the best choise in your case. Mayybe it more expensive than chiller but it is cheaper in maintainance and have a more big EER and COP.
    Oct 2001
    Nottingham UK
    5,667
    VRV and normal heat pumps are both Direct Expansion units so water freezing in cold weather is not a problem.
  1. DIY heat pump 12kW
    By kimusabi in forum Fundamentals
    Last Post: 17-10-2009, 07:50 PM
  2. frostles heat pump
  3. Will this heat pump work?
    By goodguy in forum Heat Pumps
    Last Post: 08-03-2008, 04:14 PM
  4. Rebuild air2air heat pump
    By stalker in forum Technical Speculations
    Last Post: 02-11-2006, 10:10 AM
  5. heat pump capacity adjust
    Last Post: 14-02-2006, 07:32 AM
