The use of Chiller gives flexibility in terms of capacity, I mean to say if required designed capacity of building is 100 TR then you can safely install a chiller of 80 TR because all the areas shall not be at full load at the same time. What I need to know is, is there any thumb rule or industry practice to select the ratio, what can be relationship between the two.
Thanks and best regards
