Results 1 to 11 of 11
    Jul 2007
    sydney, australia
    prestcold k150/0025
    can someone help me with some technical details on a prestcold k150/0025 3 phase compressor.
    i suspect that it is 1.5 hp but I would really like to know the displacement in cc's
    thanks guys
    Jul 2007
    united states
    43
    21
    Re: prestcold k150/0025
    Quote Originally Posted by fri11j View Post
    thanks guys
    Is that a Copeland brand?
    3,856
    Its a 1.5hp compressor. nearest one in my book is a pk15x/0025 which is the esteroil charged version. the 0025 number is the swept volume in m3/second which works out as 9.1m3 at 1450rpm. I think its a low temperature model.
    Yes its a Copeland style compressor. Valve bolt threads are unf instead of unc i think. they where built in the uk (possibly elsewhere to) and badged 'Prestcold'. Prestcold started out as pressedsteel car bodies makeing panels for Rover (i think) Don't know who copied who design wise.
    Some of the earliest ones ive seen where badged as pressedsteel, 40+ years old.
    Jon
    Last edited by monkey spanners; 22-08-2007 at 06:48 PM. Reason: Inacurate history lesson time lol
    Oct 2006
    Bucks, U.K.
    71
    604
    Hi FRI11J,
    Got out the trusty old books and this is what it says:
    K150 / 0025
    Motor HP: 1.5
    Motor kW: 1.10
    RPM: 1450
    Cylinders: 2
    Swept Vol: 8.83 m3/h
    Oil Charge: 0.86 L
    Net Weight: 43 kG
    Suction: 5/8"
    Disch: 1/2"
    Max run current: (220-240/1/50) 11.0A
    (360-420/3/50) 3.5A
    Locked Rotor: (220-240/1/50) 43.0A
    Direct Start: (360-420/3/50) 19.0A
    R12: H/LBP
    evap-40:740W@30C cond, 440W@50C cond.
    evap 0:4650W@30C cond, 3770W@50C cond,
    evap +15: 7410W@30C cond.
    note: not rated higher than +5 evap/cond @50c
    R22: M/LBP
    evap -40 1060W @ 30C cond, 680W @ 50C cond,
    evap 0: 6220W @ 30C cond.
    note: not rated higher than -15 evap/cond @50C
    R502: M/LBP
    evap -40 1530W @ 30C cond, 930W @ 50C cond.
    evap 0 6600W @ 30C cond.
    note: not rated higher than -25 evap/cond @50C
    Hope this is of use.
    Adrian.
    Jun 2005
    Stoke on Trent
    588
    If you need to know the duty at a given evap temp, give me a shout, i still have some old charts.
    amalhichem's Avatar
    amalhichem Guest
    prière envoyer les document technique des compresseur PRESTCOLD model :
    K100/0017 et K 150/0025
    mes salutations.
    Feb 2006
    derbyshire
    610
    and i have a brand fire new one,never run one the shelf gathering dust,must be 10 years old or more now.
    Jan 2008
    49
    82
    My God, i Rebuilt hundreds of these during my blue period
    Aug 2004
    Kent /SE London
    71
    14
    Hi all
    has anyone out there come across a Prestcold MALR150 condensing unit circa 1982, it is running a freezer on R12 I need to change the whole condensing unit but would rather leave the evaporator in situ, any sugestions (only helpful one please)
    cheers
    3,856
    I'd phone climate centre technical with model numbers of both the evap and condensing unit and get them to recommend a suitable replacement.
    If the evap is suitable this may be a new unit and txv for R404A. I'm not sure R134a, which would be the nearest refrigerant pressure wise, is very efficient at freezer temperatures.
    I'd also change the solenoid if the system has one as they can leak with the newer refrigerants/oils after years of faithful R12 service.
    Aug 2004
    Kent /SE London
    71
    14
    Thanks Monkey Spanners
    I will give them a ring
    regards
  1. Prestcold compressor spares
    By Pengu in forum Commercial
    Last Post: 08-05-2010, 03:03 PM
  2. Prestcold TC328
    By thcri in forum Commercial
    Last Post: 12-01-2007, 03:00 PM
  3. Wiring diagram for Prestcold Cond Unit
    By Abe in forum Commercial
    Last Post: 24-08-2005, 09:27 AM
  4. prestcold K150
    By colicool in forum Technical Discussions
    Last Post: 13-06-2005, 09:28 PM
  5. Identification of a Prestcold
    By vinic in forum Fundamentals
    Last Post: 06-01-2005, 02:23 AM
