Results 1 to 28 of 28
    Aug 2007
    37
    135
    11
    How big is your biggest???
    I'll start, biggest halls install in england is around 18 Big hall screws two stage spiral system and around 22 tonnes of ammonia. Cooling capacity of
    around 9 mega watts
    Mar 2006
    Norfolk
    160
    13
    Re: How big is your biggest???
    Go on boys - time to brag as to who has the biggest - It not how big it is, it is what you cool with it that counts.
    Interesting stuff to store
    At the moment I have pallets of ice Sculptures in my store.
    Paula
    Moscow
    34
    82
    12
    Quote Originally Posted by HallsEngineer View Post
    around 9 mega watts
    For which application?
    44
    3,800
    38
    This was the biggest job i've done since being selfemployed. Two 15hp Frascold units with two Luve evaporators. The framework is to take the weight of the evaporators as they weight 250kg dry. The room is about 10m x12m x 6m heigh. When i went there last it was so full that you couldn't get in at all, pallets stacked upto the ceiling
    Jon
    Aug 2005
    5,327
    Two-stage compression system with three levels of economizing the liquid feed. About 4,000 HP & 80,000 pounds of R-22!
    Oh yeah, all thermosiphon cooled oil coolers too.
    In a chemical plant no less...
    Aug 2003
    Netherlands
    43
    621
    15
    It's not my biggest, but the largest I have a picture off!
    In the picture 7 out of 9 at that coolcentre.
    Jan 2006
    Valrico, Florida
    517
    13
    Monkey Spanner is the housing on that evap powder coated?
    44
    3,800
    38
    Hi nh3wizard
    Its a white painted/powdercoated steel housing (from memory)
    Its about the only thing they have'nt managed to bash with the forklift!
    Aug 2007
    37
    135
    11
    Multi temp, -5, -13 intercooler and -40 lowstage.
    Oct 2003
    56
    5,519
    28
    Jon
    A really very nice job Monkey spanners. I should leave the monkey from now in you nickname.
    Feb 2007
    oldham
    44
    44
    Angry Re: How big is your biggest???
    got to be the worst condensing units on a market,we take bets to see if there is any pressure in them,and don't get me started on ascon a/c
    Aug 2007
    37
    135
    11
    God's sake dont buy Acson, contact Daikin in Manc, you can get for same price!!!
    JoeK's Avatar
    JoeK Guest
    Hi!!
    You might be interested to know that I did maintain and run a plant room with 10 mono screws installed on FES packs, going as far back as 1987. 2 stage system running cold rooms, in-line carton freezers, chilled water and A/C cooling. Plant was installed in South Africa at a large poultry processing operation. I have always been a fan of the Mono-Screw but I was surprised that it is not very popular, or so it looks to me. I am in the Industrial Ammonia side of the business in the UK.
    Aug 2007
    37
    135
    11
    I just like the noise they make
    Mar 2003
    uk
    35
    18 screws mixture of Sabroe and Howden ,9 Baltimore evap condensers ,5 blast freezers .3 -23 cold stores with 25 tonneof ammonia ..
    Mar 2008
    united states
    32
    The biggest, only system i have worked on atm is 90,000lbs of nh3. 2 stage system run by frick compressors totalling 7600hp.
    May 2008
    Australia
    Ammonia capacity - 12,000 ton atmospheric pressure storage tank - supplied one Howden 255 - 165.
    Oct 2008
    scotland
    8
    the biggest for me was 3 x Sulzer Unitop Centrifugal compressors running on about 6 ton of R22 and about 12 megawatts of cooling was the largest package unit ever made in the southern hemisphere.It was pressure tested with about 100 large bottles of Nitrogen and vacced out using three very big Edwards pumps with intakes of 2 1/8 ,about 4 weeks to fully vaccume out. that was an experience i will never forget this as about 20 years ago(the good old days)
  19. #19
    Apr 2001
    73
    5,069
    29
    3600 ton centrifugal R22 chiller.
  20. #20
    Mar 2005
    71
    639
    14
    One centrifugal water chiller at 8500ton in a single compressor.
    One R-22 system with two 6500 HP Eliott centrigual API compressors at -20 dF ET
    Numerous screw systems totaling 5000 HP or more.
    Lowest temp was a -120 dF job utilizing an oil free reciprocating compressor cascaded into ammonina high stage.
    Smallest...my home refrigerator.
    Ken
  21. #21
    Jun 2001
    N.Ireland
    45
    1,632
    Hi Guys
    mines not as big
    Single screw 321 Howden on a glycol chiller, 6600 volt motor DOL starting.
    Did design and specification on larger systems, 6mW glycol chiller comes to mind.
    Kind Regards Andy
  22. #22
    Mar 2006
    dallas, texas
    69
    108
    13
    Mine was a Huge Frozen Yogurt plant.
    -50, -40, -20 + 18 F
    10 Fes units incl. 5 321 boosters and multi 700 hp high stage
    Big freezers, tunnels, misc glycol chillers, ice builders and a huge building,, All grass roots design build in the 1980s
    Most intersting thing is that it was all auctioned off about 6 months ago.
    So much for monuments to yourself...
    bruce
  23. #23
    hi-speed's Avatar
    hi-speed Guest
    2000ton 134 a centrif 3400# charge
  24. #24
    Jan 2006
    Norway
    40
    801
    4
    22
    in cooling capacity it would have to be a 1100 Kw RSW cooling system (roughly 1.000.000 K/cal if I'm correct).
    Amount of refrigerant it would be 11 metric tons of NH3 of a freezing, cooling and freezedrying plant
    -Cheers-
    Tycho
  25. #25
    Jun 2006
    British West Indies
    545
    13
    The biggest I ever did was a Rosie, she was 42-39-56, you could say she had it all
    Take the V out of HVAC and you are left with a HAC job
  26. #26
    Nov 2006
    44
    710
    around 9 mega watts
    14 sabroe screws -40 + - 10 , approx 35 tonne charge around 12 mega watts
  27. #27
    Jul 2006
    Romania
    38
    97
    12
    the biggest plant on which i was worked it was 4 chillers in paralel york vsm-89 ...each one capacity 5300kw ,500 liters oil each, 1300 kg of R410a each,electrical motor supplyed by 6600v 150amps running at 100% ...
    once i replaced one electrical motor and 2 times i replaced the compressor
    Such of nice job!
  28. #28
    Jul 2008
    1
    For this past year, how about the installation of a 4000 Ton water chiller, powered by a 13 psi steam turbine (70,000 #/hr steam flow), 2 x 5000 ton electrics driven by VFDs, a 4000 Ton electric on VFD, and then two 5000 tonners, one driven on a steam turbine, the other on electric with VFD !!
  1. Biggest VRF installation in the world?
    By hendrag in forum Air Conditioning
    Last Post: 06-10-2010, 12:56 AM
  2. Whats the biggest system on R410A?
    By raison in forum Refrigerants
    Last Post: 08-07-2008, 09:03 AM
  3. Biggest refrigeration forum in the world!
    By benncool in forum Chit Chat & Service Stories
    Last Post: 15-03-2005, 06:30 AM
