    Mar 2007
    London, UK
    Smile air conditioning questions and answers
    hi everyone
    was just wanting a bit off help in making up some questions and answers for a small exam off 5 questions for my boss, so he can test people in interveiws.
    be so greatful for your help
    cheers sid
    Mar 2006
    Lancashire
    1,859
    28
    Re: air conditioning questions and answers
    1) Name 3 symptoms of a blocked condensor
    2) What is the function of the evaporator
    3) What is superheat? and how/where to measure it
    4 what should a system be vacuumed to
    5 What is the purpose of the reversing valve
    just some general ones that i can think of... Not to hard and pretty basic.
    Hope this helps
    Marc
    11,025
    I thought that most questions nowadays were something along the line of...
    1. Done this before ?
    2. Can you drive ?
    3. When can you start ?
    Mar 2006
    Lancashire
    1,859
    28
    2. Can you drive ?
    True but i think making potential employees sit a simple test before they start would be a great idea
    Feb 2006
    Mumbai
    49
    1. Three symptoms of blocked condensor.
    a) Temperatures not achieved in the air conditioned area.
    b). High discharge pressure drop leading to higher power consumption.
    c) Tripping of compressor.
    2. Function of evaporator.
    Function of evaporator is to facilitate transfer of heat from the air conditioned area to the liquid refrigerant flowing inside the heat exchanger.
    Vijay Kumar
    HVAC Design Engineer
    BMCPL
    "The more you sweat in peace less you bleed in war"
    Mar 2006
    Lancashire
    1,859
    28
    symptoms of a blocked condensor?
    1) High suction pressure
    2) incresed current draw
    3) High head pressure
    4) reduced efficency
    Function of an evaporator?
    to evaporte the liquid into a superheated vapour
    What about questions 3,4 and 5?
    11,025
    I think the problem is that sometimes the person asking the questions is not always fully conversant with the answers.
    It would perhaps be prudent to include one of the firms technicians somewhere in the interview process to get a 'feel' for the newcomer.
    Oct 2006
    CORDOBA -ARGENTINA
    75
    Since 40 years at field service , the hard to know answer to new technician is.
    Why the evaporator is full ice blocked if fan is run?
    Why a part of a evaporator is part ice blocked.?
    When a evaporator is full wet at the evaporators coil turns , and fins? What does it means?
    Which is one of the main reason for a High pressostat trip , furthermore that it was an increase in discharge pressure , why it happens ?
    Which are one of the most reason of faults?
  1. apprentice requesting answers
    By napoleon in forum Technical Discussions
    Last Post: 25-01-2006, 08:37 AM
  2. Starting a compressor, and receiver questions.
    Last Post: 24-08-2002, 12:37 PM
