Thread: Leak tracer for R407c
12-08-2007, 01:45 AM #1
Hi Guys
has anybody ever used this kind of leak tracer that You mix with the refrigerant in the system??? I have a pretty large plant with Kms of pipes and this thing (if it works) should make my life a lot easier....
Evapcoil
12-08-2007, 12:19 PM #2
Re: Leak tracer for R407c
Well,
All the UV dyes works reasonably well.
But if you go down that route then get the most powerful UV lamp you can find and remember that it is hard to see the dye in strong sunlight.
12-08-2007, 02:16 PM #3
Let's see... I'll try... Unfortunately We don't have too much bright sun light down in the engine..... :-)
Thanks Viking
12-08-2007, 04:45 PM #4
Be sure to use the goggles that come with the lamp, or you won't spot the dye so well. Ive found a leak on the weld on a drier with it where you'd never think to look, and around the electrical terminals on a compressor where you would'nt want soapy water!
I use Spectroline Dye. It will have a dosing rate baseded on the oil or refrigerant qauntity of the system.
Jon
13-08-2007, 10:30 PM #5
hy evapcoil...i was in your situation 2 yrs looking for leaks all the time in a 407 c system but on a cruise ships...did u have a refrigeration centralizate system?i use always electronic leak detector and i was lucky many times....which kind of compressor did u have...let me know i try to be heplful with you...
14-08-2007, 05:21 PM #6
ciao evapcoil..this solution of leak tracer is good for automotive a.c....keep going on old solution cause in my opinion is the best that one by closing valve on each area...mihai
Leak detectors
By Temprite in forum Tools and CalculatorsReplies: 54Last Post: 18-08-2010, 04:15 PM -
Evasive gas leak
By Feeze in forum Technical DiscussionsReplies: 24Last Post: 18-08-2008, 07:22 AM -
Help!!! Shell and Tube Evap Leak
By tommy Gun in forum Trouble ShootingReplies: 7Last Post: 22-07-2007, 12:45 PM -
Tiff 5000 leak detector
By davidchesson in forum Tools and CalculatorsReplies: 6Last Post: 06-11-2006, 04:26 AM -
Can't find leak with UV Dye
By jd_boggs in forum TransportReplies: 6Last Post: 16-09-2006, 06:22 PM
