Thread: Re-steming a Regulator
16-08-2007, 02:58 AM #1
Got a brand new reg here, has a cga580 stem on it, I want to put in a cga350 which I have the stem for. Heres my problem, the damn stems round, no way to grab onto it, and its in too tight to remove by hand. How would you recommend I get the stem to unscrew so I can screw in the cga350 to use my ethylene.
16-08-2007, 04:51 PM #2
Re: Re-steming a Regulator
Bump anyone?
16-08-2007, 05:29 PM #3
Does it have a hex/allen shaped hole in it? Like the uk ones. Failing that i would take it to a welding supplies shop as they would deal in a lot of regulators and may have the correct tool to chage the stem.
16-08-2007, 07:35 PM #4
Good idea thanks, no hex or allen, but going to bring to a place, that or file a flat groove to grip on.
Safe pressure testing with gauge manifold
By alexdouglas1969 in forum FundamentalsReplies: 27Last Post: 16-09-2007, 04:37 AM -
Crankcase Pressure Regulator
By Abe in forum Technical DiscussionsReplies: 32Last Post: 10-09-2006, 01:56 PM -
hotgas and crank case pressure regulator
By abbasi in forum FundamentalsReplies: 8Last Post: 27-02-2006, 01:54 PM -
New TFC regulator
By Carlo Hansen in forum New TechnologiesReplies: 15Last Post: 26-02-2005, 08:39 AM
