Thread: overhaul
    cha09's Avatar
    cha09 Guest
    overhaul
    please give me suggest, may I use compressor more than 5000 hour for the first time, my NH3 compressor is a reciprocating compressor, two stage, Sabroe 116
    Aug 2005
    5,302
    Re: overhaul
    It would be best to use the Sabroe guidelines for replacement intervals. Remember, these operating hours are recommended average hours. A compressor that is treated badly may require more frequent inspection and replacement of parts. This is only something you can decide.
    I have seen compressors that are treated well and never been taken apart also.
    malaysia
    159
    Re: overhaul
    you are recommend to perform minimum check/s.
    these days, QC for compressor before delivery is on random basis.
    you wouldn't know if you are to 'choosen' one with defective parts.
    it is good to check & change the lube oil; moreover some manufacturer place some cloth type filter at the strainer. if you do not check, ....
    perform the isnpection if you trust onyl what you see.
    Denny Thuss's Avatar
    Denny Thuss Guest
    Re: overhaul
    Quote Originally Posted by cha09 View Post
    just do it my friend, don't forget to check the alignment, and ofcourse to remove the cloth type filter at the strainer.
    Jan 2008
    West Coast British Columbia
    106
    Re: overhaul
    I would say 10,000Hrs seems to be the rule of thumb with Recip. The diminishing factor to these hours is the Stop Start
    Somerset
    69
    4,697
    Thumbs up Re: overhaul
    CHA09.
    Check out the attachment. It Should help with your service interval dilemma
    Somerset
    69
    4,697
    Re: overhaul
    CHA09.
    Also open this doc as it's to be used in conjuction with the other.
    Cheers Grizzly
  1. advice needed on overhaul hours
    By stewartreith in forum Industrial Compressors
    Last Post: 15-05-2006, 08:59 PM
  2. Overhaul compressors
    By Peter_1 in forum Industrial
    Last Post: 26-04-2006, 08:52 PM
