    Feb 2007
    Bedford
    38
    Mitsubishi Heavy Industries
    Hi all : Does anyone have another technical service apart from HRP for Mitsubishi Heavy Industries Units.
    Also accessing technical manuals. Have a problem with cassette E9 fault (Condensate pump) our Northern engineers have replaced Pump, Float swicth and PCB still same problem. ( Before you shout theres nothing wrong with Norherners.)
    Freecool
    Aug 2003
    Netherlands
    49
    620
    21
    Re: Mitsubishi Heavy Industries
    Water not draining due to drain plugged?
    Apr 2006
    stafford
    42
    974
    Paul
    "KEEP IT COOL"
    icecooldude's Avatar
    icecooldude Guest
    Quote Originally Posted by Freecool View Post
    Freecool
    you dont stae which model cassette you are refering to.if it has a drain probe as well as float switch try cleaning sensor as any slime or water borne muck will give a wrong reading.you dont state waht temperature you are running your return air at or the air off temp. i have recently had the same problem and found the customer trying to cool a print room down to 18c.if this is the case up your temperature to 22c and watch your problem vanish.
    Feb 2007
    Bedford
    38
    Thanks for your comments, will take on board what you say icecooldude is the drain sensor situated in the condensate tray? havent been to site yet and no info from office on model.
    Sanshinman's Avatar
    Sanshinman Guest
    Not sure if you've tried this but there's a company called 3D, they are owned by HRP but they actually know what they're talking about no. 0208 668 1112.
    Best of luck,
    Trevor.
    Jul 2007
    Malta
    43
    8
    listen Freecool.
    Im working on Mitsubishi Heavy Ind..I have the most of the manuals.Ussualy im fixing the faults on AC at the company.I will be happy if i can help you out.If you still have the problem write what you have been checked and done so far.I always can open a unit and have a look close.
  1. fault codes for mitsubishi heavy industries air con
    By mal in forum Trouble Shooting
    Last Post: 21-10-2006, 06:20 PM
  2. mitsubishi heavy
    By ric in forum Air Conditioning
    Last Post: 01-09-2006, 11:18 PM
  3. Troubleshooting Mitsubishi Heavy VRV System
    By Cofreth in forum Trouble Shooting
    Last Post: 29-08-2006, 05:41 PM
  4. Mitsubishi Heavy Industries HELP
    By Bakerbj in forum Air Conditioning
    Last Post: 26-07-2006, 03:18 PM
  5. MITSUBISHI Heavy Industries
    By coolit24 in forum Air Conditioning
    Last Post: 06-03-2006, 08:46 AM
