Untitled
Ashbury
2013
Page 2 of 2 FirstFirst 12
Results 51 to 59 of 59
  1. #51
    Apr 2009
    home
    15
    Re: wats the best tool for freon leak detection
    Quote Originally Posted by jess View Post
    i normally use leak spray or soapy water but always wonder is the a better method, are these fancy electronic jobs any good??
    Look at the ninth poston page 1 of this thread.... its an Inficon.... except no imitations its the best you can get next to a halide torch
  2. #52
    Dec 2009
    Spain
    34
    235
    4
    I would suggest Ultraprobe. They have different models depending their sensitivity and also the chance to vary the search frequency. And no matter which gas you are looking for, that's a good point when using ultrasound technology.
    http://www.uesystems.com/
    Ultrasonics also have other applications, for example, to check bearings in compressors before you go to vibrations, or checking leaks in valves, etc.
  3. #53
    Jul 2011
    Manchester
    26
    3
    You can have it of INFICON. There are several other companies just you need to Google it.
  4. #54
    Feb 2001
    Tampa Florida
    1,091
    14
    Odd to see a forwarded message in so many months. The TIF model is still by far the best for supermarket use. The reason I like the TIF is the software. You can ramp it up and down and actually home into a leak. Inficon and others pretty much tell you are getting close and then telling you that you are getting farther Sort of like the old game when your children are telling you that you are getting warmer or colder. Plus, the TIF has a 25 year warranty, although they don't quite deliver on it in a timely basis.
    Ultrasonics are underemployed, in my opinion, mostly because technicians are not quickly adaptable to them. Accu-trak and Am-probe have a good product. I have an off brand I bought online that has a 12-inch parabolic dish that saved the day a while ago. We turned everything off in the market... lights and all. It indicated a suction line leak near an exhaust fan in the deli area. We were at our wits end with that one, but were able to pinpoint it after the ultrasonic provided the weak high frequency signal that a leak provided and we were off with our TIFs and bubbles to find it. Leaks underneath armafllex and behind walls are the trickiest, and ultrasonics to not fare well with them.
    But beyond the equipment, the finest leak detector is a technician who is seasoned enough to employ all six senses and experienced as a construction technician... Knowing the most likely places to look, the signs of oil saturated insulation, the likely rub spots, etc.
    It's one of the reasons we bring our service techs out of the construction department whenever we can.
  5. #55
    Oct 2003
    5,352
    Quote Originally Posted by Dan View Post
    ...You can ramp it up and down and actually home into a leak. Inficon and others pretty much tell you are getting close and then telling you that you are getting farther ...
    You can do this also with an Inficon
  6. #56
    Oct 2010
    Sweden
    29
    4
    I use this myself and can defenitely recommend it. It has a rather long startup sequence though, often 1,5 minutes...
    A nice feature is the NH3 optional sensor.
  7. #57
    Nov 2011
    india
    13
    I too agree that Tek-Mate is a reliable leak detector..And what you often need to do is check it instantly in order to see if it is working fine..And i am comfortable using this detector..
  8. #58
    Feb 2001
    Tampa Florida
    1,091
    14
    We check ours everyday. Spare sensors are a must. Keep them charged. I remove the battery and well as some of our tech do; they sometimes drain. They have problems with the vacuum motor sometimes. But an awesome warranty. It takes more than a month to get one back, but so far Tif has honored the warranty on 10 of them
    . We have 20 of them. And I will stand by any technician who uses any other brand and I always win. It's the software that out performs the others. You can reset it's sensitivity much better than a D-tech, Yellow Jacket, etc.
    How do we test them? We start them up in the office and walk into the warehouse. They are screaming. Then we lower the sensitivity and find leaking bottles, or hoses on our reclaim machine. I have a 30-pounder that is supposedly empty and it has been caught leaking for 3 years. It is one of our most important tools and all our techs understand to treat them and charge them and store them carefully.
    t
  9. #59
    Feb 2001
    Tampa Florida
    1,091
    14
    I am still a Tiff fan. It outruns the teck-mate every day of the week.
  1. Ultra sonic leak detection
    By clivet in forum Tools and Calculators
    Last Post: 30-08-2010, 04:26 PM
  2. Law and Leak detection
    By Bakerbj in forum Fundamentals
    Last Post: 21-03-2006, 11:39 PM
  3. Ultrasonic Leak Detection
    By Derek in forum Refrigerants
    Last Post: 06-05-2005, 07:15 PM
  4. Helium for leak detection
    By chemi-cool in forum Refrigerants
    Last Post: 08-03-2005, 02:53 PM
  5. Leak detection
    By Reeferjon in forum Trouble Shooting
    Last Post: 10-12-2001, 12:58 PM
