Results 1 to 2 of 2
Thread: Moisture Calculation
09-08-2007, 10:22 AM #1
Hi everybody,
I am looking for a software to calculate humidity, any one know any software or tool please tell me.
Thanks you very much
09-08-2007, 10:49 AM #2
Re: Moisture Calculation
Hi hlacviet
Welcome to this forum
The calculation of moisture removal does not need a software to be done. Just u need to know two psychometric properties for the air before and after dehumidification process and go to psychometric chart to determine the difference in humidity content in the air and know the air flow rate then u can calculate it from this relation :
moisture removal = air mass flow rate * (W1 - W2)/100 ....kg
W1 = inlet air humidity ratio g/kg
W2 = outlet air humidity ratio g/kg
I wish it could help
how can we calculation industrial refrigeration
By lam sanh in forum System OptimizationReplies: 34Last Post: 28-02-2011, 02:31 PM -
Moisture
By Abe in forum Trouble ShootingReplies: 29Last Post: 07-08-2007, 05:50 PM -
Cooling load calculation
By raviperumal in forum Technical DiscussionsReplies: 6Last Post: 02-03-2007, 05:09 AM -
Moisture in Propane Liquid
By Nizar in forum RefrigerantsReplies: 4Last Post: 24-07-2006, 04:12 PM -
Moisture loss calculation
By gregorm in forum Technical DiscussionsReplies: 15Last Post: 15-05-2006, 04:23 PM
