Results 1 to 10 of 10
    makalu112's Avatar
    makalu112 Guest
    1950 Prestcold Fridge Needs Repair
    Hi, I have a 1950 Presctold Fridge that has just died.
    Model number l33765.
    Our fridge engineer tried to add a new thermostat on the back to no avail. It started briefly but stopped about a minute later.
    he thinks maybe a new compressor may work with re-newed gas. But is unsure.
    We live in Midhurst West Sussex - does anyone have any knowledge of how to get the old gal going again?
    Any info gratefully received. Can anyone give advice or come and mend it?!
    Oct 2006
    1,843
    21
    Re: 1950 Prestcold Fridge Needs Repair
    Quote Originally Posted by makalu112 View Post
    That diagnosis seems resonable to me.
    Cheers taz.
    Jul 2006
    Trinidad
    64
    15
    changing the compressor is a good thing , but I think you will have to change the condenser ,to match these high velocity compressors on the market now.
    Jun 2005
    Stoke on Trent
    588
    Not sure if a modern compressor will fit in as from memory these old Prestcolds had pancake compressors mounted on a spring frame ......... oh my god, am I really that old! but yes it is possible. Another alternative would be to fit a remote condensing unit if the fridge does hold sentimental value but a compressor failing after 50 odd years, tut, tut, we expect longer than that from them!
    Jun 2007
    South Africa
    66
    120
    That fridge is older than most of the technicians nowadays!
    If it has sentimental value, try to revive it with a new evaporator, condenser, compressor. The looks will offset the price.
    What do you charge to get it to South africa?
    Apr 2001
    2,099
    27
    This is my advice Makalu.......
    Dont try fix it by putting in new modern parts....
    ie: compressor or the like.
    Those pan cake compressors are the best things ever invented, and they kicked forever. Try and obtain one from somewhere, there still kicking about Im sure.
    Your fridge needs a loving restoration..........not a repair
    And its worth a few bob I would think.
    Think carefully before you start messing about with it.
    pss: Any chance of a picture please?
    Jan 2007
    SPAIN
    172
    Seen reference to "pancake" compressor: any photos?
    Does it refere to the external appearance of the unit?
    If so, how is the inside organized: coils low down and pistons at top like current hermetics? - as a kid I was not allowed at the back of the fridge - took too many things to pieces .
    When refrigerant velocity is being referred to: is it correct that R134a fridges make up low thermal capacity by pushing around a (relatively) small quantity of gas very fast rather then a (preferable ?) greater quantity of higher thermal capacity R12 ?
    This difference in operation therefore leads to the substitution problems mentioned above ?
    What of FX56 used around here?
    Jun 2007
    Cyprus
    73
    252
    Methinks the first thing you need is a proper refrigeration engineer. Sack the one you got because anyone who fits a thermostat and then smartly shifts his diagnosis to 'failed compressor' is frankly not worth letting in through your door. But if we assume that this diagnosis IS the correct one, and at this age it probably is. Then a replacement is needed. I can't see the problem here (apart from the mounting method of the original). Get your (new) engineer to obtain a R12 compressor of suitable duty, make up a simple base mounting for it, install it and recharge with R49 or FX56... job done.
    MendallFridge's Avatar
    MendallFridge Guest
    We are a refrigeration company in East & West Sussex who have been trading as a Ltd Co. for 30 year and would be happy to discuss your problem. Call Michael on 01323 872255 or 0797010468 to discuss how we may help you.
    Mendall Refrigeration Limited
    Jul 2008
    London
    848
    Quote Originally Posted by MendallFridge View Post
    One year and two months -that's a fair time to keep someone on hold
    Multisync
    london
    P.S advertising alert!
  1. Fridge part of frost-free fridge-freezer icing up?
    By rumpelstiltskin in forum Domestic
    Last Post: 01-06-2010, 09:56 AM
  2. crazy 3rd-world idea: aircon from small fridge
    By lsemprini in forum Fundamentals
    Last Post: 29-05-2008, 01:10 AM
  3. Should dial change fridge temperature??
    By Trisha in forum Trouble Shooting
    Last Post: 12-02-2007, 08:00 PM
  4. help- my bar fridge is wacko?!
    By ben in forum Trouble Shooting
    Last Post: 25-01-2002, 12:06 AM
  5. is my fridge working properly?
    By vincec in forum Trouble Shooting
    Last Post: 15-01-2002, 09:55 PM
