    Mar 2006
    Lancashire
    1,859
    28
    bubble temperature?
    hi just been looking through a few questions that iv been set for a course but im a bit stuck on one of the questions...im not asking for the answer but an expanation... Im not sure what "bubble temperature" or "dew" temerature are... Can anyone help
    In relationship to refrigerant blends, temperature glide is
    a) discharge line temperature – suction line temperature
    b) dew temperature – bubble temperature
    c) bubble temperature – evaporating temperature
    d) dew temperature – condensing temperature
    3,856
    Re: bubble temperature?
    Mar 2006
    Lancashire
    1,859
    28
    thanks for that.... so the answer is B?
    Feb 2007
    55
    The dew point temperature is generally associated with the refrigerant in its gaseous state.Bubble point is the refrigerant in its liquid state.Due to the nature of blended refrigerants you will find that each component either evaporates or condenses at slightly different temperatures thus causing the temperature glide,this of course is different for each type of blend.Some manufacturers also use the mean pressure which is effectively the mid point in the glide.
    Hope this helps.
    Aug 2007
    china
    9
    thanks a lot!
    Mar 2006
    Lancashire
    1,859
    28
    Thanks for the help guys
  1. fun quiz
    By Brian23 in forum New to RE
    Last Post: 02-10-2007, 10:18 PM
  2. re ref. circuit
    By shsalameh in forum Fundamentals
    Last Post: 06-08-2007, 12:59 PM
  3. removing humidity
    By Sledge in forum Air Conditioning
    Last Post: 22-06-2007, 05:40 AM
  4. Q=? h1=? mechanical schematics
    By fridg in forum Technical Speculations
    Last Post: 19-03-2006, 01:43 PM
  5. Article in ACH&R News
    By Gary in forum Fundamentals
    Last Post: 20-05-2003, 12:27 AM
