Thread: punctured discharge line
05-08-2007, 04:11 AM #1
I sit possible repair a punctured discharge line with solder, JB Weld, or even a compression fitting
05-08-2007, 09:02 AM #2
Re: punctured discharge line
Why the multi postings??
You are just clogging up the system.
To answer your question, NO you can't use the methods you mentioned.
Depending on what gas your system runs on, the pressure can reach anything up to 40 Bar.
The only repair you could get away with is Brazing but preferable that section of pipe should be replaced.
(Note; I only reply in this tread, the answer is valid for the rest of them as well)
05-08-2007, 09:14 AM #3
The Viking is absolutely correct. Replace the high pressure pipe line instead of trying to repair the same.
05-08-2007, 11:41 PM #4
The best answer is NO.
DO not touch it, get an expert.Brian - Newton Abbot, Devon, UK
Oil Leak in NH3 Discharge Line Flange
By NH3LVR in forum IndustrialReplies: 9Last Post: 26-05-2007, 09:15 PM -
trap in discharge line?
By frozen ocean in forum Supermarket RefrigerationReplies: 4Last Post: 11-12-2005, 03:29 PM -
Exploded discharge line
By Peter_1 in forum IndustrialReplies: 1Last Post: 05-05-2004, 09:47 PM -
Prssure drop in discharge line.
By lin in forum CommercialReplies: 10Last Post: 16-10-2002, 02:22 AM
