Results 1 to 2 of 2
Thread: Frick RWB II Plus Rev D Micro
03-08-2007, 09:19 PM #1
I recently had a RWB II micro freeze on me resulting in a compressor failure, when the micro froze the safeties failed, the compressor totally unloaded and the liquid injection became inactive. The alarm circuit and safety circuits under this condition became inactive. The failure was eventually found to be caused by faulty suppressors holding the package run relay in. If anyone has experienced a similar failure and found a way to repair this fault by forcing the micro to shut down or to cut the signal from the run relay, please forward me your findings.
04-08-2007, 10:40 AM #2
Re: Frick RWB II Plus Rev D Micro
Frick XJF/XJS 120 compressors
By 404cab in forum Industrial CompressorsReplies: 21Last Post: 15-11-2011, 03:57 PM -
Frick Premature Seal Failures
By Steve Wright in forum Industrial CompressorsReplies: 32Last Post: 11-06-2010, 02:34 PM -
FRICK TDSH 233 Slide Valve and guide damaged
By 404cab in forum Industrial CompressorsReplies: 9Last Post: 30-07-2008, 11:24 PM -
Frick Micro Control Panel Problem
By derfriguy in forum New to REReplies: 7Last Post: 11-04-2007, 07:45 AM -
old frick system monitor
By rasgrant in forum NH3Replies: 5Last Post: 17-01-2007, 07:15 PM
