03-08-2007, 05:40 PM #1
Building a fridge with a window ac unit
Would it be possible to make a fridge with a small ac unit half stuck in an insulated box?
thanks
Joseph
03-08-2007, 05:47 PM #2
Re: Building a fridge with a window ac unit
Wouldn't last long as the monooblock units aren't set up for it, with some modification ya might succeed.
03-08-2007, 05:50 PM #3
What is the Monoblock? And how does it imapct this concept?
thanks
04-08-2007, 02:15 AM #4
04-08-2007, 02:48 AM #5
A mono block is a window A/C, your average one that is, they are designed to have a high evap temp and high air flow, that cools the compressor along with the fan.
For a fridge, or what we'd consider one @ 4C you will need to change the expansion device, preferably a TXV, you'll need to take measures to ensure good compressor cooling, and you'll need to change the thermostat system to one in the right temp range.
For Good efficiency you'll all so want to split the evap to help retard the ingress of heat.
04-08-2007, 09:18 AM #6
04-08-2007, 02:10 PM #7
Why would I buy one when I live next to the recycling yard and get free ones?
window unit
By paul o in forum Air ConditioningReplies: 9Last Post: 18-07-2007, 04:35 AM -
Off-line Mitsi VRF leaks!
By sinewave in forum Air ConditioningReplies: 8Last Post: 05-06-2007, 11:18 PM -
can a r22 split system condensing unit be used to cool a display fridge
By tsangep in forum RefrigerantsReplies: 8Last Post: 20-05-2006, 04:21 PM -
is my fridge working properly?
By vincec in forum Trouble ShootingReplies: 1Last Post: 15-01-2002, 09:55 PM
