Results 1 to 11 of 11
03-08-2007, 02:40 AM #1
Hot wire auto AC clutch to be on all the time
Dads truck AC quit working
I looked at it
The clutch on compresor was not engaging
Measured volts at 3 volts
Put 12 volt hot wire on and the clutch engaged and he had air back
How long could I have that jumper on for
I dont have time to go looking for why it wont work right now.
What are the draw backs of using it with the jumper and a switch for now?
03-08-2007, 02:45 AM #2
Re: Hot wire auto AC clutch to be on all the time
03-08-2007, 08:52 AM #3
Find the fault and fix it! If you simply run 12 volts to the clutch then you will freeze the evaporator up which will restrict air flow to the cabin and you run the risk of liquid refrigerant returning to the compressor and popping the compressor
Karl
03-08-2007, 08:41 PM #4
That's assuming that it isn't short of gas.
It may be only 3 volts because a pressure switch isn't properly made.Last edited by Brian_UK; 03-08-2007 at 09:14 PM.
03-08-2007, 09:05 PM #5
Might be off on a highpressure switch, may be about to go BANG!
06-08-2007, 07:00 PM #6
Have you checked how many amps the compressor is pulling?
3v sounds like a bad connection or a bad contactor."If Hannah was an air handler, I would be a condensing unit so I could open her TXV and pump my refrigerant through her coils." - a HVAC friend of mine
07-08-2007, 03:24 AM #7
It is a CAR Air conditioning , the 3 v is applied to the clutch.
The compressor is driven by the Carīs motor.
No amperage to measure .
AND NEVER NEVER jump the controls that drive the clutch.
take your time to check all the way the current run from battery to clutch.
Normally is the AC on of , the thermostat and the high low pressure switch.
08-08-2007, 07:50 AM #8
Ya, by passing controls is how stuff usualy goes boom, It's like in the movies, how the guy never just hits the alarm and calls for back up but instead goes to check it alone and doesn't follow protocall! If he'd had just sounded the alarm and called back up they'd win! (Makes a dam short movie though!)
09-08-2007, 12:46 PM #9
Next Step... throw some gauges on it. Weekend is comming!
16-08-2007, 03:21 AM #10
Turns out it was bad wires from the clutch
Fixed both wires where there was a solderless connector and it is perfect now.
Thanks for the replys
16-08-2007, 05:44 AM #11
Good show mate, glad to hear your back chillin in the summer traffic!
Daikin Schedule Time Clock
By breckle in forum Air ConditioningReplies: 1Last Post: 12-06-2007, 11:57 AM -
what do you do on your off time?
By Tycho in forum Chit Chat & Service StoriesReplies: 15Last Post: 09-10-2006, 12:03 AM -
Pull-down time for residential unit
By TooLittleTimeZZ in forum DomesticReplies: 25Last Post: 18-03-2006, 01:27 PM -
HP Switches (Manual or Auto)
By Latte in forum Technical DiscussionsReplies: 9Last Post: 02-06-2005, 07:48 PM -
Time delay for multi compressors
By iceman007 in forum Air ConditioningReplies: 5Last Post: 06-11-2004, 08:05 AM
