    Apr 2007
    United States
    Adjusting superheat on multiple evap units
    What is the best technique to adjust the superheat on a multiple evaporator unit?
    Should I close off the solenoid valve for one evaporator and adjust the valves when they are the only one supplied with refrigerant or is it best to adjust and balance the expansion valves with both supplied with refrigerant?
    It seems to me both techniques have issues.
    If each is adjusted separately, the compressor becomes over capacity for the single evaporator.
    If both are left running, I'd think it be quite the challenge to balance the real pressures and refrigerant flows through the different valves since the settings on one would effect the overall pressures in the entire system.
    I think I'm tempted to start with each valve isolated from the other and once close, then balance them together.
    I guess I'm asking, what is the best practice?
    Thanks!
    Win
    Oct 2005
    IRAN
    878
    Re: Adjusting superheat on multiple evap units
    Hi there,
    I assume you have multiple evaporators connected to one compressor.
    First of all the piping (suction and liquid) become very important. If piping is not correct then adjusting one TEV will effect the others.
    If piping is done correctly then there is no problem. You can adjust the valves separately which gives the proper super heat for that evaporator.
    The correct piping arrangements are given in ASHRAE Refrigeration Handbook chapter 2.
    I have done this with three evaporators with one compressor for -40°C rooms. There were 12 rooms.
    11 of them had correct piping and there was no problem. One of the rooms suction pipe was done wrongly. When one TEV was adjusted then the other two were messed up.
    My suggestion is the piping. Check them first then try to adjust the TEVs. If piping is not correct then it will be a waste of time with no success.
    Even Einstein Asked Questions
    Apr 2007
    United States
    Lana,
    Again, many thanks. I've ordered up a copy of the handbook.
    Win
  1. Carrier 23xl chiller-Low discharge superheat alarms
    By Bradysmill in forum Trouble Shooting
    Last Post: 25-04-2010, 07:43 PM
  2. Multiple ref. units for cold stores
    By smpsmp45 in forum Commissioning
    Last Post: 21-06-2007, 06:02 PM
  3. Superheat
    Last Post: 23-08-2004, 05:54 PM
  4. How do you calculate Superheat?
    By zolar1 in forum Training
    Last Post: 10-05-2002, 02:37 AM
