    Jun 2007
    IRAN - ASSALUYEH
    47
    23
    Question suction line freezeing
    Dear all my co worker.
    thanks for visiting my comment.
    our plant we have the air condition pakage unit(DX type).
    the suction normal operation pressure is 4 bar during the suction line freezes the suction pressure goes down near 1.5 bar and then the suction line be comes freeze.weanwhile the refrigerant of system is enough.
    why the suction line freezes?
    Mar 2006
    Malaysia
    48
    233
    Re: suction line freezeing
    Hi karimihassan
    Welcome to this forum,
    Ok if the suction line only freezes without the compressor and u mentioned the normal suction pressure is 4 bar and u got 1.5 bar it sounds u have excessive suction pressure drop inside the line causes the suction temperature to drop drastically and makes the frost coating. Each drop in suction pressure 1 bar the temperature drops to 3 K in R-134a. so u have at least 7 to 9 K in AC and most frequently the evaporating temperature of 7.4°C so the suction temperature reaches below zero.
    Does ur system have accumulator ? if yes check it size it may be oversized selection of accumulator.
    Check all the fittings and valves and the suction line design.? more data give more light.
    Mohamed
    Sep 2005
    Singapore
    59
    145
    Quote Originally Posted by karimihassan View Post
    What is the on coil and off coil air temperature across the evaporator?
    Probably a plugged air filter or evaporator coil or even a loose fan belt will cause this problem too.
    Mar 2006
    Malaysia
    48
    233
    Quote Originally Posted by Cofreth View Post
    All the prevoius causes the evaportor to frost obvoiusly and then the suction line and the compressor
    Oct 2005
    IRAN
    878
    Hi there,
    Measure the superheat and make sure that no liquid is flooding.
    Check the sub-cooling too.
    1- LP low, SH high, SC normal, no temperature drop in liquid line ------------- Lack of expansion device capacity
    2- LP low, SH high, SC normal, temperature drop in liquid line ---------- pre-expansion
    3- LP low, SH high, SC low ------ Lack of refrigerant
    4- LP low, SH low -----------Lack of evaporator capacity
    Even Einstein Asked Questions
  1. Suction gas <-> liquid line heat exchange and performance gains
    Last Post: 18-05-2010, 01:52 PM
  2. Suction line designing for ref. systems
    By Maxim in forum Fundamentals
    Last Post: 16-12-2006, 05:43 PM
  3. Measure suction line pressure drop with thermometer
    By Steve Wright in forum Fundamentals
    Last Post: 17-09-2005, 11:05 PM
  4. Minimal required R134a speed in suction line
    By DaBit in forum CPU Overclockers
    Last Post: 08-05-2002, 05:19 AM
