Thread: R 404 A
    Jun 2005
    Canada
    15
    R 404 A
    What type or (brand name) lubrication oil is used for R404A refrigerant.
    3,853
    Re: R 404 A
    For R404A you need Ester oil. I've been using ICI Emkarate as it is what the local wholesaler stocks.
    Available in three grades/viscosities 32,46,68 dependant on the type of compressor used and the temperatures you are running at.
    Some compressor manufacturers recomend thier own brand of oil for certain compressors (special additives).
    Phone up the compressor manufacturer or their distributor and see what they recomend.
    Jon
    Jun 2005
    Canada
    15
    Question Re: R 404 A
    The unit is cooling up -10 degree centigrade with semi hermetic Copland compressor
    Kothari
    May 2006
    china
    98
    Re: R 404 A
    Hi, kothari, you can use ester oil such as EAL, Arctic, 22CC, Emkarate RL 32H and so on.
    Jun 2005
    Canada
    15
    Re: R 404 A
    Thanks,
    Kothari
