Dear techs:
I am in the process of overhauling an old condensing water pump. The brand of the pump is yet unknown. What I am certain of is that the shaft is supported by two bushing type bearing inserts located at each end of the pump casing. I was able to press out the shaft and impeller, but I am not sure on how to get the buhings out of their holes. They look fragile, and I don't want to try prying or tapping . Any suggestions welcomed. By the way, they are about 40 mm I.D. and about 2 mm thick.
