Thread: urgent
    Mar 2005
    Nearby
    22
    urgent
    Dear Friends
    It is a pleasure if u can be of any help :
    In some DX air conditioning systems using R134 we face a problem :
    During operation oil is discharged from crank case and then the compressor jams . In reciever sight glass there is thick layer of oil (8 - 10 mm) .
    We came 2 conclusion that the reason is :
    1-Using fake oil or refrigerant ?
    2-As we had the compressors repaired, newly installed oil rings are not working properly so piston sucks oil into chamber and discharges it, as it happens in reciprocating engines causing oil to be burnt.
    Jul 2007
    Australia
    1,845
    Re: urgent
    Is this a newy designed system, or a retrofit of an old r12 air con plant?
    If its a new system is the system designed correctly to allow oil return?
    If it's an old retrofit, then obviously the design is OK, but what oil are you using, how many oil changes did you do?
    Apr 2006
    phil
    5
    Re: urgent
    please note: oil used in in 134a is different from r12
    Mar 2005
    Nearby
    22
    Thumbs up Re: urgent
    With so many thanks.
    Yeap .It is a retrofit cycle but all the procedure in order to change the system has been done correctly.
    Even the oil has been selected appropriately(poly ester)
    But there is something u should know :
    Compressor , Evaporator and condensor are on the same level ( Packaged system )
    Apr 2001
    79
    5,071
    35
    Re: urgent
    Quote Originally Posted by A_Ahed View Post
    What was the original refrigerant? Did you change the TXV?
    Mar 2005
    Nearby
    22
    Re: urgent
    The original refrigerant was R 12 and we had the TXV changed.
    Nov 2006
    India
    7
    Re: urgent
    Did you check the cranckcase heater functioning? this seems to be related to flooded start situation. Do you have the pump down cycle?
  1. urgent
    By Dimitris in forum Trouble Shooting
    Last Post: 18-10-2006, 05:55 AM
  2. Urgent G Fault Codes Needed
    By botrous in forum Trouble Shooting
    Last Post: 08-08-2005, 08:13 PM
  3. Urgent, Kirchoff question
    By Peter_1 in forum Fundamentals
    Last Post: 20-01-2004, 03:12 PM
  4. Urgent!!! S.O.S. - nozzle size
    By herefishy in forum Fundamentals
    Last Post: 25-05-2002, 10:29 PM
