Thread: Daikin twin split
25-07-2007, 11:45 PM #1
Daikin twin split
Does anyone know the dip switch settings for a daikin skyair twin split ? Someone prior to myself has decommissioned a twin split to be re-installed within the same building at a different level . On re-commissioning we have a UA fault ???? Too many evaps .... would appear to me that the dip switches may have been fiddled with or accidentally changed during storage. Any help gratefully appreciated .
26-07-2007, 12:01 AM #2
Re: Daikin twin split
If you give me the model number I can find out for you.
Otherwise, if you go to www.daikin.co.uk you are able to download the manual (but again, you will need the mod no)
28-07-2007, 06:28 PM #3
Problem solved , the installer added an extra cable to P1 & P2 which weren't required.
Daikin not working... many problems
By stankovicv in forum Air ConditioningReplies: 26Last Post: 11-12-2010, 09:01 AM -
Daikin, Why do we bother?
By gwilliamson in forum Air ConditioningReplies: 21Last Post: 02-02-2010, 09:38 AM -
Daikin Multi Split A/C problems
By timholmes204 in forum Air ConditioningReplies: 6Last Post: 22-05-2008, 12:09 AM -
Daikin Controllers
By airefresco in forum Air ConditioningReplies: 5Last Post: 15-05-2008, 08:08 AM -
!!big Daikin Problem!! Codes,u4,pj, And E0
By airconengineer in forum Air ConditioningReplies: 21Last Post: 31-05-2007, 09:04 PM
