Results 1 to 10 of 10
Thread: cylinder adapter
05-02-2008, 11:07 PM #1
cylinder adapter
Guys
does anyone know where i can obtain one of these:
http://www.toolfetch.com/Category/We...&sort=2&page=3
i bought a nitrogen test rig off SRW and it comes with a female connection, hence the adapter
alec
07-02-2008, 07:34 AM #2
Re: cylinder adapter
Hi Al, Contact that site and ask them the cost of shipping it to you.
Regards NormMy wife used to say you never listen to a word I say at least I think that what she said
07-02-2008, 07:43 AM #3
Alec.
Try BOC/ Their Agents, ( Or their equivlant in Ireland). Basically I assume any " Industrial Gasses" Stockist should be able to help.
Or have you already been there? In which case
the post is self explainatory!
And Norm's is a good suggestion.
Grizzly.
07-02-2008, 11:54 PM #4
thanks for the replies, i'm still awaiting an answer from the site, i'll probably try to get something made up
thanks again
alec
08-02-2008, 12:33 AM #5
The adaptor fits a universally standard gas bottle connector.
I would imagine that your regulator has a standard female thread in it.
Have you tried your local, nearest, gas bottle supplier or supplier of pressure regulators, they should be able to supply spare parts.
Come to that, why not go back to SRW ?Brian - Newton Abbot, Devon, UK
08-02-2008, 12:37 AM #6
Welding supplies company should be able to get a new 'thingy' to screw into your existing regulator and to fit standard bottles.
10-02-2008, 01:44 AM #7
Alec
Have a look at these 2 links, it's the best I can find.
I hope they are of use?
http://www.wellyweld.com/categories/Adaptors_163.aspx
http://www.wellyweld.com/categories/Extensions_162.aspx
10-02-2008, 02:00 AM #8
Thanks for that, i've had to order an adaptor from the states, SRW don't want to know!! thanks for the help fellas
Alec
10-02-2008, 02:36 AM #9
Alec,
Can I just ask you to clarify one thing?
You are going to fit this adaptor straight in to a regulator, without any hoses in between, aren't you?
Reason I ask,
The only test rigs I ever seen has been designed to fit downstream of a regulator fitted on the cylinder.
Normally I would expect to see a hose coming from the test rig with a female connector for a regulator on it's end.
These rigs would not been designed to take the pressure in the OFN cylinders and would probably explode if connected without a regulator...
(And I never seen a regulator sold without the cylinder connector in place, as it's a vital part of the regulator, to be strength tested by the manufacturer)Last edited by The Viking; 13-04-2008 at 09:52 PM.
10-02-2008, 10:48 PM #10
Hi Viking
The adaptor is to fit to a 2 stage nitro regulator, not to attach the test rig direct to the bottle, i presume it being a brass fitting that it can handle the pressure??
thanks for the advice though
al
Grasso - 9 cylinder Compressor - Ammonia
By rlmts in forum Industrial CompressorsReplies: 24Last Post: 04-10-2010, 07:39 PM -
Round duct adapter on City Multi PDFY
By emes in forum Air ConditioningReplies: 4Last Post: 08-02-2008, 08:21 PM -
vacuum in a recovery cylinder?
By flyboy3b in forum New to REReplies: 6Last Post: 24-09-2007, 09:38 PM -
Old Cylinder Disposal
By Derek in forum RefrigerantsReplies: 6Last Post: 09-02-2005, 09:24 PM -
cylinder of aluminium
By milton in forum Tools and CalculatorsReplies: 1Last Post: 16-01-2004, 02:02 PM
