Results 1 to 2 of 2
Thread: Piping identification system
24-07-2007, 11:25 AM #1
Here is a good info in PDF format
http://eng.lacity.org/techdocs/maste...5/15030SSS.pdf
24-07-2007, 01:45 PM #2
Re: Piping identification system
You should be aware this specification is for a waste water facility. Some countries/locations may have a specific color code they want to use.
In some instances, water piping may be green, while natural gas may be yellow. I remember seeing one some time ago that stated refrigerant piping should be brown (I think?).
If the local government specifies the pipe color code then this is what should be used.
I don't think there is a uniform color code for pipe identification. Perhaps someone will find something...If all else fails, ask for help.
Daikin fault codes
By Chris2005 in forum Air ConditioningReplies: 45Last Post: 21-03-2012, 10:09 PM -
System Burn Out Troubleshooting
By altaf22m in forum Technical DiscussionsReplies: 13Last Post: 07-05-2010, 09:24 AM -
Burn out System, Clean up procedure. & Troubleshooting.
By altaf22m in forum CommercialReplies: 19Last Post: 15-04-2008, 07:03 PM -
Piping diagram for VRV system
By wilks in forum Air ConditioningReplies: 6Last Post: 10-07-2007, 06:55 PM -
Refrigeration system proposal; comments please.
By DaBit in forum Technical SpeculationsReplies: 13Last Post: 01-01-2003, 03:42 PM
