Thread: Inverter's outdoor pcb
23-07-2007, 08:58 PM #1
Recently in Malta we have experienced a major low voltage and also frequent power cuts for a whole week.During this whole month have not stopped discovering faulty electyronic pcbs of the outdoor unit of inverter type domestic air conditioners.
All vrvs tested indicated a seized compressor(locked).But what is usually faulty is the inverter card.It costs a lot of money and most clients decided to replace the whole a/c unit instead of repairing.What I actually noted is the is a certain amount of corrosion on the track side of the same pcb.Is there any spray sealed that could be applied to prevent such corrosion?
23-07-2007, 09:07 PM #2
Re: Inverter's outdoor pcb
Well, they are normally varnished on the back.
So I assume that any normal non corrosive, non conductive varnish could be used...
23-07-2007, 09:55 PM #3
Its called "Conformal Coating" . RS components sell aerosols of it. A good electronics distributor should stock it.
Pacific Inverters?
By mick2me in forum Air ConditioningReplies: 3Last Post: 30-07-2006, 10:14 AM -
DC vs AC inverters
By Josip in forum Technical DiscussionsReplies: 4Last Post: 04-02-2006, 07:10 AM -
Inverters
By Latte in forum Air ConditioningReplies: 19Last Post: 31-12-2005, 04:13 AM -
inverters and rcd's
By rbartlett in forum Air ConditioningReplies: 11Last Post: 11-10-2005, 07:14 PM -
Frequency inverters
By Peter_1 in forum ElectricalReplies: 6Last Post: 15-07-2004, 07:46 PM
