Thread: Aircon condensing units
23-07-2007, 04:18 PM #1
I'm goin to install an a/c unit in my new conservatory. I want to mount condensing unit on side of house (about 7ft above ground level) Do I need planning permission or is it ok to go ahead and put up. You will be able to see condensing unit from street. (United Kingdom)
23-07-2007, 05:06 PM #2
Re: Aircon condensing units
The only way to be sure is ask the local authority. We have a domestic customer that insisted I guarantee that permission wasnt needed, there are to be 2 small units on a wall above flat roof that cannot be seen or heard from anywhere. After asking the local authority, they said it would be a good idea even though it was unlikely it was required. That was 8 weeks ago and we are still waiting for a definite answer!!
23-07-2007, 05:22 PM #3
+1
There are just to much difference between the local councils...
23-07-2007, 05:57 PM #4
There are variations in councils, but in general if it can be seen or heard by neighbours or the general public you will need to investigate planning permission.
23-07-2007, 08:53 PM #5
And don't forget that you must also inform the local electricity supplier that you are installing AC as they will need to know the maximum demand increase.
24-07-2007, 12:37 PM #6
Hi Lucas,what is your observation on the surrounding? Do u see any condensing unit around? If yes then go ahead and install but if not then consult the athaurities.
Lifting Condensing units!
By daddymac in forum Air ConditioningReplies: 35Last Post: 09-02-2009, 11:11 AM -
HAIER aircon units
By A/C student in forum Air ConditioningReplies: 30Last Post: 27-01-2008, 06:08 PM -
Condensing Units
By DHASHU in forum Technical SpeculationsReplies: 13Last Post: 22-07-2005, 03:24 AM -
Sizeing condensing units
By Latte in forum CommercialReplies: 4Last Post: 25-11-2004, 09:26 PM -
Parellel Condensing Units
By bersaga in forum Technical SpeculationsReplies: 9Last Post: 08-05-2003, 02:12 PM
