Results 1 to 1 of 1
20-07-2007, 06:14 AM #1
PRESSURE RELIEF CALCULATIONS in cascade system
hi,everyone
i am sizing the relief valve on the oil seperator of the low-tempreture stage.there have two rule per ASHRAE Standard 15 Mechanical Refrigeration Safety Code:
1.HIGH-STAGE OR SINGLE-STAGE COMPRESSORS: Flow is to be calculated based on 50°F (10°C) saturated suction temperature at the compressor suction.2.LOW-STAGE OR BOOSTER COMPRESSOR: For those compressors that are capable of running only when discharging to the suction of a high-stage compressor, flow is to be calculated based on the saturated suction temperature equal to the design operating intermediate temperature.
follow 1 rule,the valve size is such large that i can't believe the result.but,l think the 2 rule is not fit in cascade system.
how to size? i need your help.
thanks
Daikin fault codes
By Chris2005 in forum Air ConditioningReplies: 45Last Post: 21-03-2012, 10:09 PM -
System Burn Out Troubleshooting
By altaf22m in forum Technical DiscussionsReplies: 13Last Post: 07-05-2010, 09:24 AM -
fun quiz
By Brian23 in forum New to REReplies: 6Last Post: 02-10-2007, 10:18 PM -
***** System Pressure Relief
By trong40 in forum FundamentalsReplies: 7Last Post: 31-07-2003, 12:26 PM
