Results 1 to 19 of 19
Thread: Question re: Cooling Sea Water
Threaded View
05-07-2007, 12:35 PM #1
I need to maintain 400 liters of salt water at 6°C in a closed system. Outside air temperature at peak cooling periods averages between 18 and 22°C, but can be as warm as 30°C. The tank is 12mm molded plexiglass. Commercial cooling units rated for sea water available here range in power output from 350 to 4000 watts. How much power do I need? (Circulation pump achieves a throughput of approx 350L/Hour, if that is indeed relevant).
Thanks for your help.
Cooling down the water in a 1000 liter container
By Joep Hogenhout in forum Technical DiscussionsReplies: 29Last Post: 21-04-2009, 01:27 AM -
cooling water TDS
By afeef in forum Technical SpeculationsReplies: 1Last Post: 19-04-2009, 07:38 AM -
Cooling tower evaporation, blowdown, makeup and cycles
By miltbeychok in forum IndustrialReplies: 5Last Post: 14-10-2005, 06:34 PM -
By miltbeychok in forum FundamentalsReplies: 0Last Post: 13-10-2005, 05:14 AM -
Building a wine cabinet
By Rory in forum Technical DiscussionsReplies: 38Last Post: 13-07-2004, 08:28 PM
