Thread: Auto defrost
    kevinandjackie's Avatar
    kevinandjackie Guest
    Unhappy Help any ideas
    Hi Everyone
    Does anybody know?
    I will try not to bore you with the in's & out's
    MFI Fridge about four years old. Schreiber APP 6302
    Similar to Electrolux and a few other's
    I think there all about the same going on the research i've done,
    It has drain channel at back from either side to the middle, then channels forward into a deep bowl section at the front of the fridge, where there are two clear square, I believe salad container's.
    Now whats puzzling me is.
    There an hole under these clear container's
    that allows conden or if it is auto defrost does it run down and through this hole (I dont know)
    only it drips though on to the floor, or is there ment to be a bung in it.
    I do know that on most auto defrost there is an hole
    with a pipe that directs it into a small tray on the top of the motor in which the heat of the motor dries it up. This is not that designed.
    I would appretiate some info if anyone know
    Many thanks Kevin
    Last edited by kevinandjackie; 21-07-2007 at 01:03 PM. Reason: Retitled due to little response
    Oct 2004
    Scotland
    1,454
    21
    Re: Auto defrost
    It has Drain channel at back from either side to the middle, then channels forward into a deep bowl section at the front of the fridge,
    Where the channels from the left and right meet up is there not a hole?
    I can't remember seeing a hole in the very bottom.
    Any chance of a picture or link to the fridge?
    With your post count below 15, you may have to PM me the picture or link and I will post it for you.
    Chillin
    and go get a cuppa
    Re: Auto defrost
    Hi Chillin out,
    I will try and send an image only i am new to this, but thanks for coming back to me.
    Oct 2004
    Scotland
    1,454
    21
    Re: Auto defrost
    The hole should just go straight through the floor of the fridge and drip onto the base itself.
    Either there should be a small hose directing it into the proper 'tray' or there is a hole in the tray.
    Is there a 'tray' (built in, not removable) that has a hot pipe from the comp going into it?
    Chillin
    and go get a cuppa
    Exclamation Re: Auto defrost
    Quote Originally Posted by chillin out View Post
    Chillin
    Hi it looks like you said it goes into a tray which is part of the undercarrage, but i can't see anything like a warm pipe that will cause it to evaperate. That was my concern. only i am about to fit these in to a mobile home and a bit worried it could rot floor in time. I have had them running a week now fridge and freezer all seems to be fine, but i have just check the tray and there quite a bit of water in there. what would you suggest. Here three more photos.
    THANK FOR YOUR TROUBLE
    TetraFluor's Avatar
    TetraFluor Guest
    Re: Auto defrost
    hey, try to make this tray reachable from the front of your fridge so you can check/empty it manually from time to time.
  1. Freezer Room Defrost
    By Samarjit Sen in forum Commissioning
    Last Post: 21-06-2007, 06:16 AM
  2. electromagnetic defrost heat pump?
    By star882 in forum New Technologies
    Last Post: 08-03-2007, 10:09 AM
  3. defrost on freezer coldroom
    By andyh in forum Electrical
    Last Post: 01-09-2006, 10:12 AM
  4. Hot Gas defrost suction pressure regulation
    By 87mustang in forum Technical Speculations
    Last Post: 05-08-2005, 07:25 AM
  5. Hot Gas vs. Electric Defrost
    By herefishy in forum Technical Discussions
    Last Post: 08-03-2005, 07:50 PM
