13-07-2007, 02:17 PM #1
accumulator (vertical gas/liquid separator)
Hi guys,
How can i size an accumulator for domestic refrigerator?
I have some documents from net but they are mostly about big systems.I can't find accumulator design methodology for refrigerators.
Have u got any documents for sizing vertical separators?
Pls help for my thesis dissertation.Last edited by omer26; 13-07-2007 at 02:47 PM.
13-07-2007, 02:46 PM #2
Re: accumulator (vertical gas/liquid separator)
HI and welcome to the RE forums.
Originally Posted by omer26If all else fails, ask for help.
13-07-2007, 03:47 PM #3
The primary function of the design engineer is to make things difficult for the fabricator and impossible for the serviceman.
17-07-2007, 12:10 PM #4
13-07-2007, 04:49 PM #5
On bigger systems they need to have a big enough volume to be able to hold at least half the total system charge as a minimum. I think for a domestic fridge sized system you will be limited as to what you can by off the shelf, unless you will be making it youself.
Jon
13-07-2007, 06:31 PM #6
Look on the net for AC&R. They make a standard line of accumulators and sizing is based on refrigerant and evaporating temperature. Do not go too large in size and watch the note about minimum capacity. Too low and the velocity in the pick up tube will not return oil.
Ken
17-07-2007, 12:06 PM #7
Thanks for all your helps.
oil separator questions
By rublet in forum Trouble ShootingReplies: 10Last Post: 23-06-2008, 02:01 AM -
NH3 separator desing
By Rio69 in forum NH3Replies: 5Last Post: 03-01-2007, 09:33 PM -
Oil circulation, oil separator effect
By aruiloba in forum Technical SpeculationsReplies: 19Last Post: 11-02-2006, 10:21 AM -
Diagrame Of Oil Separator
By skags in forum Technical DiscussionsReplies: 9Last Post: 15-10-2005, 11:18 PM -
Oil separator
By Peter_1 in forum IndustrialReplies: 23Last Post: 12-05-2004, 04:01 PM
