    Oct 2002
    Hampshire
    156
    22
    I need to build two coldrooms
    Hello all...
    Right, i have a question(or ten), i need to build two coldrooms...
    Family friend has just bought a farm blah,blah and wants two coldrooms...one freezer for -22degC and a chiller for +2degC.
    Both rooms are going to be 6ft deep 6ft width and 6ft tall, i have no idea of wall thicknesses etc as of yet, but i am just wondering if there were any sites on the internet that can select condensor units and evaporators for you...
    I have seen some software somewhere before, where all you do is type in the spec of the coldroom...i.e insulation,thickness etc... what product,what ambient blah,blah... and the software selects what you need...perhaps one of the manufactures has this kind of software, but what i am really looking for is somewhere i can download this software if poss so i can have a play...
    Coldrooms arent really my industry....
    i was going to modify a transport unit, but i need two, so i think this is the way to go....
    What do you rekon.... two condensor units and two evaps(seperate systems) or is it possible to use one condensor unit and two evaps?
    And as for refrigerants, my guess...freezer 404a? chiller 134a?
    I want both units to have electric defrost and the evaporators/compressor will be controlled by digital display thermostat(eliwell or similar), preferd t/stat cut out method?.....thermostat switches contactor for compressor, or to pump down by using a soleniod valve.
    I have fitted up a few small coldrooms before, so the piping and wiring isnt a problem...just the selection...
    Can anyone help?
    Much appreciated...thanx..
    Jun 2001
    N.Ireland
    1,630
    Cold Room Selection
    Hi, Alpha
    If you are in the UK Dean and Wood have a selection program available from their site.http://dean-wood.co.uk
    They also have contact details for technical assistance, this you will need if your are sizing your first rooms.
    As a starter 3-4" thick for chill insulation and 5-5" thick for deepfreezer dependant on material chosen and final room temp.
    If you download the program and require any help feel free to post. The program will select standard D&W equipment, you may need a hand selecting the pricise configuration needed.
    Regards. Andy.
    Oct 2002
    Hampshire
    156
    22
    Thanks for that Andy...yep, im in the UK, i will have a look on D&W site, cheers... kind of looking forward to this, makes one hell of a change from transport...
    Any questions, and i know where im gonna ask...be ready lol...
    Much appreciated..ta..
    5,668
    You can also download an equipment selection program from www.prestcold.com/link.cfm but you need to know what your duty required is
    frank
    Apr 2002
    Samoa
    13
    What about refering your query to a sigificant refrigeration wholesaler. They would proberly do the calcs for you and select the correct equipment(albeit theirs) for you, maybe assist in supplying the room as job lot or at least tell you where to get it.
    Steve
  1. Coldrooms
    By klimek in forum Tools and Calculators
    Last Post: 04-07-2010, 01:09 PM
  2. Want to build a refrigerator-like cooling for my cpu
    By PeeWee in forum CPU Overclockers
    Last Post: 13-11-2008, 05:37 AM
  3. Grease build up
    By Andy AC in forum Commercial
    Last Post: 10-06-2006, 12:52 AM
  4. Can an amature build a homebrew temprite???
    By FNQ Bunyip in forum Fundamentals
    Last Post: 23-02-2005, 10:44 AM
