Results 1 to 11 of 11
    Jun 2006
    ATHENS / GLYFADA
    Problem with an inverter compressor in V.R.V system DAIKIN R 407
    Hello my friends, how are you?
    We have too many work with the weather here in Hellas ( Greece) .
    I have a real problem too ask you today.
    Does anybody knows if a simple compressor can work in the place of inverter?
    In a system V.R.V. DAIKIN R 407 II.
    Somebody told me that it can work , because my client can pay to change the inverter.
    Thank you very much.
    Harris from GLOBALKLIMA S.A. Greece.
    Aug 2001
    1,046
    Re: Problem with an inverter compressor in V.R.V system DAIKIN R 407
    What do Daikin advise you to do?
    VRF compressors are subject to mechanical stress and temperature not found in other systems.
    They know what their products will do. They may be able to give you a clue.
    Feb 2007
    2,473
    45
    I can't see how you would be able to run the inverted compressor without the inverter, the controls would not accept it.
    BUT, if it's a twin compressor unit , then you can set the outdoor unit to run in "emergency" mode. This will run the fixed speed compressor without the inverted one. The system will function but only provide 50% of it's duty. Just make sure that there isn't a fault with the inverted compressor, if it for example suffered a burnout then the fixed speed compressor will not last either.
    Jun 2006
    ATHENS / GLYFADA
    Good morning my friend.
    Do you have the settings for the unit ( its a twin unit 300.000 btu ) .
    How can i set it to work without the inverter compressor?
    I know that they have a setting to do that but i dont know the settings.
    Thank you for the reply.
    Feb 2007
    2,473
    45
    Harris,
    If you give me the model number, I can find out for you.
    Otherwise, you could check with your Daikin supplier (but they will also ask you for the exact model, as the controls are different for the different units)
    Jun 2006
    ATHENS / GLYFADA
    Quote Originally Posted by The Viking View Post
    Harris,
    My friend i think is RSXYP30
    I say i think because i dont have it in frond of me.
    Feb 2007
    2,473
    45
    The most important bit is the first letter after the numbers, this will tell us which series the unit is from and thus what generation controls you are looking at.
    Mar 2007
    45
    78
    On old g series there is a switch on the main pcb. It says emerg/norm . switch the switch to emerg . I do not know if this will work on the system you are working on but is worth looking.
    Jun 2006
    ATHENS / GLYFADA
    Thank you very much my friends.
    Everything you need from me ill be there.
    Jun 2006
    ATHENS / GLYFADA
    I let you know if it works.
    Nov 2007
    London
    461
    no it won't work!!
    Quote Originally Posted by Harris Greece View Post
  1. Daikin fault codes
    By Chris2005 in forum Air Conditioning
    Last Post: 21-03-2012, 10:09 PM
  2. Problem with ducted Daikin
    By jutty in forum Trouble Shooting
    Last Post: 23-07-2007, 05:34 AM
  3. strange inverter problem
    By rbartlett in forum Air Conditioning
    Last Post: 19-05-2006, 08:31 PM
  4. Migrate Oil problem - Medium Refrigeration System
    By lurioda in forum Fundamentals
    Last Post: 24-02-2004, 06:20 AM
