Thread: Flushing Agent
    dallas's Avatar
    dallas Guest
    Flushing Agent
    We have flushed out a system following a mechanical failure with the compressor.
    We are having trouble getting the system below 1000microns and feel that there is still flushing agent in the system.
    We have done the following:
    - blew through flushing agent with nitrogen
    - broken the vacuum 4 times
    - had all components removed from the system during flushing
    - heated up the system to boil off the flushing agent.
    We are now about to start up the system with regular liquid line and suction line drier changes.
    Anymore ideas???
    Oct 2006
    Bucks, U.K.
    71
    604
    Re: Flushing Agent
    Sustained Pressure test?
    Fresh oil in vac pump?
    Apr 2006
    stafford
    42
    974
    Re: Flushing Agent
    new vac oil and using the 3/8 line instead of the 1/4(if your vac pump has the option) ive found this not saves time but achieves better results quicker for me personally
    Paul
    "KEEP IT COOL"
    Aug 2003
    Netherlands
    49
    620
    21
    Re: Flushing Agent
    What did you use to flush?
    Test the vac pump by putting the vacuum meter on it directly and see if it will pull down futher!
    Otherwise do a pressuretest and leave it pressurized for 24 hours. No drop in pressure? Do an other blowtrue with nitrogen, check your hoses and pull it down again!
    Nov 2005
    New Zealand
    550
    Re: Flushing Agent
    Hi Change the oil in your vac pump and it turns grey again then you still have moisture. What kind of system is it?. Is it possible to drill a hole at the lowest point and drain water as I used to do, but then I am talking big centrifugals.
    Regards Toosh
  1. Pipework Flushing
    By frank in forum Air Conditioning
    Last Post: 22-08-2009, 07:15 PM
  2. How can we service and flushing evapurator
    By shameer in forum Air Conditioning
    Last Post: 01-11-2006, 04:35 PM
  3. Flushing oil from a system.
    By djbe in forum Commercial
    Last Post: 26-06-2006, 02:20 PM
  4. Eathanol As a flushing Agent
    By Mastercool in forum Technical Speculations
    Last Post: 06-06-2006, 09:34 PM
  5. System flushing
    By Mickvee in forum Air Conditioning
    Last Post: 18-09-2005, 07:20 PM
