Thread: Boiling point of quickshot ?
08-07-2007, 09:29 PM #1
Hi all,
I am sure they thought of this when designed the stuff, but anyway something has just occurred to me.
If you put quickshot in a system, then vac it out will it evaperate
regards
raymond
09-07-2007, 02:38 AM #2
09-07-2007, 10:40 AM #3
Re: Boiling point of quickshot ?
This stuff's an additive - is that right, Ray?
I think Ray's question was about the ability of the additive to evaporate in the vacuum.
I'm always suspicious about additives of all types because of the residues they tend to leave behind.
Effectively, if you add a solution to a refrigerant, you end up with a zeotropic mixture, however minute the ratio.
09-07-2007, 03:23 PM #4
My apologies-I was thinking of Hotshot, the Refrigerant.
Can someone point what's wrong
By Peter_1 in forum IndustrialReplies: 30Last Post: 22-04-2008, 07:04 PM -
on a totally different point - way to go the bhoys
By WebRam in forum Chit Chat & Service StoriesReplies: 7Last Post: 22-11-2006, 11:09 AM -
Building a wine cabinet
By Rory in forum Technical DiscussionsReplies: 38Last Post: 13-07-2004, 08:28 PM -
Low Temp Low RH Room
By David PS in forum Technical SpeculationsReplies: 9Last Post: 07-05-2003, 04:30 AM -
Psychrometrics
By Prof Sporlan in forum FundamentalsReplies: 12Last Post: 01-12-2001, 06:48 PM
