    44
    3,800
    38
    So much for an early finish
    "hello, ive got to keep pressing the reset......"
    And this is what i found.
    The first shows the leak, the second the fix and the third how tight it was
    70
    10,624
    52
    Re: So much for an early finish
    Great job, what did you do - lift the unit out, fix it and then put it back?
    44
    3,800
    38
    Luckily the units where on a stand which was at just the right hight to lean over and get at it with the pepperpot burner on the oxy kit. Good job it was only leaking on the top where the copper is joined to the steel condenser as it would have been a right pain to get at the underside.
    Was in a rush as the milk tanker was waiting outside to pick up the evenings milking, or so i thought. It turned out he parks on site an picks up in the morning but no one thought to tell me
    I've seen quite a few of these prestcold/copeland units leak here, always worth a check if you can't find a leak.
    Jon
  1. Positive air pressure system
    By LRAC in forum Commercial
    Last Post: 17-10-2008, 06:27 AM
  2. Early retirement?
    By shogun7 in forum New Technologies
    Last Post: 04-01-2005, 08:37 AM
