Results 1 to 20 of 20
Thread: Water Chilling
Threaded View
08-07-2003, 07:39 PM #13
Hi Quinton
the oil is cooled by a glycol solution for frost protection. Glycol/water mix is circulated thru a second coil in the evaporative condenser. Oil coolers are more commonly shell and tube, but always cleanable. Rubbered, semi welded plates are often used on chiller for evaporator, the semi refers to the fact that they wouln't have any rubbers on the refrigerant side, only the process side.
Dave
those contactors sure do keep you on your toes, even though the voltage would dictate smaller contactors for the load they are always generously sized.
Regards. Andy
Hoshizaki Ice Maker
By Abe in forum Legal-Business-MarketingReplies: 19Last Post: 01-05-2010, 03:27 AM -
Water in *****
By chemi-cool in forum RefrigerantsReplies: 47Last Post: 17-08-2009, 10:16 PM -
Fact or Fiction
By david.findlay in forum FundamentalsReplies: 40Last Post: 09-03-2009, 06:19 PM -
cold river water
By eftimios in forum FundamentalsReplies: 8Last Post: 09-11-2008, 06:37 PM -
open cycle R718 A/C that also provides high purity water?
By star882 in forum Technical SpeculationsReplies: 7Last Post: 27-07-2006, 04:18 AM
