Thread: Booster System
22-06-2007, 07:56 AM #1
Booster System
Hi everybody,
Is there anybody who knows booster system or has experience about this system?
Thank you very much your interest
Regards,
Arda Atay
Junior service engineer
22-06-2007, 03:09 PM #2
Re: Booster System
What kind of booster system are you referring to?
23-06-2007, 01:07 AM #3
Re: Booster System
23-06-2007, 09:58 AM #4
Re: Booster System
For me , a booster system is where the discharge of the LP (freezer)is going into the suction of the HP system (cooling)
Am I right?
This is often used in NH3 and I once serviced a supermarket pack system.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
23-06-2007, 07:50 PM #5
Re: Booster System
I didnt know if he was referring to a 2 stage ammonia system, booster compressor?
23-06-2007, 11:24 PM #6
25-06-2007, 02:59 PM #7
Sorry everybody about short information
This system is going to use in a hypermarket.This system is suggested compressor company.I want to know that how the system works..( especially system diagram is the best for me)...and What kind of advantages and disadvantages are there?...and which operation value are u suggest?
This system is working with R404a
Regards,Last edited by zapoy; 25-06-2007 at 03:01 PM.
25-06-2007, 03:38 PM #8
Re: Booster System
A booster compressor is a separate compressor. The type of system this is used in is called a multi-stage system. This means the refrigerant is compressed more than one time.
In a two-stage system, you have a set of compressors that work like this:
a) The booster compressor pulls in low pressure gas and compresses it to an intermediate pressure.
b) This gas at an intermediate pressure is hot and needs to be cooled before it flows into the next compressor. This cooling process is called desuperheating or intercooling.
b) A second compressor called the high-stage compressor pulls in the intermediate pressure gas (now cool) and compresses it up to the condensing pressure.
Two stage systems are used to promote energy efficiency, but they can be more complicated to understand and work on.If all else fails, ask for help.
Daikin fault codes
Fan model for system optimization
By autt in forum System OptimizationReplies: 8Last Post: 31-03-2007, 05:34 AM -
Refrigeration system proposal; comments please.
By DaBit in forum Technical SpeculationsReplies: 13Last Post: 01-01-2003, 03:42 PM
