Results 1 to 8 of 8
Thread: Annie A2-12
    May 2006
    Isle of Wight, Uk
    47
    424
    Annie A2-12
    Hello guys, I have recently obtained an annie a2-12 compressor tester. Upon reading the instruction manual, I've found out that is the 60Hz only version - a bit disappointing. My question is can I still use it for starting compressors?, as it will be fed with 240v 50Hz. I guess that the other functions wouldn't be accurate because of the frequency change as it is set up for 60Hz, but I only ever use it for starting.
    Any thoughts appreciated
    Andy
    Jul 2006
    New Zealand
    77
    65
    Re: Annie A2-12
    Can,t see why you would not be able to use it..
    The start bits are only switches and capacitors.
    Oct 2003
    5,630
    34
    Re: Annie A2-12
    Quote Originally Posted by suny View Post
    Hi Andy AC
    Either u throw it away or use a Electronic Frequency Inverter to reduce the 60Hz to 50Hz & 240V to 230V. I hope this will solve ur problem
    suny
    Suny, have you ever seen or used an Annie starter?
    Oct 2006
    Bucks, U.K.
    71
    604
    Re: Annie A2-12
    Andy,
    If a 60Hz unit, will it not be designed / rated for 120v?
    This will mean caps (and transformer?) are wrong voltage.
    I havent used one of these, so not sure if a transformer is present....somewhere there was a circuit on a previous thread.
    Adrian
    May 2006
    Isle of Wight, Uk
    47
    424
    Re: Annie A2-12
    You can feed it on 110 or 220v power @ 60hz, I still haven't got around to giving it a go but I will let you know what happens.
    Andy
    Jun 2007
    Sri Lanka
    88
    Re: Annie A2-12
    Dear Peter_1
    I am very sorry for the comments I made. By an oversight I misunderstood it. Therefore I would kindly request you to delete the above post of mine.
    Suny
    May 2006
    Sterling, IL
    13
    Re: Annie A2-12
    Why not write or call Thermal Engineering about your question.
    Apr 2005
    Sheffield, England
    43
    Re: Annie A2-12
    I have the same unit which my sister sent me from the USA. I have used it as is to start and reverse 240/50hz compressors no prolbem.
    If no sure get an old scrap compressor from a dump site and test.
  1. Annie A-12 hermetic compr tester
    By Peter_1 in forum Electrical
    Last Post: 30-04-2010, 02:50 PM
  2. Annie A-3
    By rdf2001 in forum Tools and Calculators
    Last Post: 04-06-2007, 10:47 PM
  3. Annie model A-12 analyzer
    By chiller563 in forum Tools and Calculators
    Last Post: 17-11-2005, 07:44 PM
  4. Annie A-12 repair
    By 2002kahuna in forum Electrical
    Last Post: 21-07-2005, 04:10 PM
  5. Good old annie
    By Cary in forum Tools and Calculators
    Last Post: 27-03-2005, 10:25 PM
