Results 1 to 13 of 13
Thread: internal thermo switch
15-06-2007, 10:44 PM #1
hi, i was wondering can someone explain why a compressors internal thermo strip may activate..even though.. the gas charge is ok.. compressor mechanical parts ok..all others like fans coils etc are ok..and installation in general seemed good..have come across this on some compresssors!
cheers
15-06-2007, 10:47 PM #2
Re: internal thermo switch
It is probably going O/C because of high current.
Check the resistance of the windings according to the manufacturers specification.
and go get a cuppa
15-06-2007, 10:53 PM #3
16-06-2007, 03:29 AM #4
Those are heat sensitive, so look for things that might contribute to higher than normal heat.
High suction superheat
high discharge pressures
broken discharge valves will add a lot of heat
low voltage
loose connections on motor or starter
Those are some quick things I can think of.If all else fails, ask for help.
16-06-2007, 09:00 PM #5
Most compressor motors are wound with a thermal sensor in each phase, so a 3 pase comp has three in series wound deep into the windings.
If as you say everything is fine with the comp then I would check the thermistor modual itself.
They have an internal relay that can fail.
With normal running they can trip and then once the comp has been reset they run as if there was no problem.
If in doubt and if you have proved all is well with the comp then change the thermistor modual.
taz.
17-06-2007, 08:58 PM #6
Is it a Maneurop compressor?
They need some cool gas back to stop them overheating.
Earth leakage is unlikely, 1000v megga test it though.
18-06-2007, 08:22 PM #7
18-06-2007, 08:34 PM #8
I think he meant that maneurop rely on some liquid returning to the comp to keep it within working specs.
and go get a cuppa
18-06-2007, 10:00 PM #9
Thanks for the comments lads.but sorry forgot to mention that these compressor i come across are inverter driven, and has a thermo switch connections on the shell with phase connecrtings...compressor runs for a while however not 100%... could it be the high volts/frequencey when looking for more duty that makes thermo open....all conditions i said at the start still apply another words every thing seems to be good however slight grounding..
18-06-2007, 10:05 PM #10
19-06-2007, 03:12 PM #11
there fitted for two things,over current and overheat,or on three phase machines ,mainley over temp,unless its something like a star point protector[old stuff now] witch does both on most machines ,over about 1 horspower most have contactors and overload units for overcurrent protection/phase loss and if the compressor is stressed and getting hot the current should go up anyway and trip,no expert on inverter yet as not had many breakdown, there are inverter checkers available now but make sure the systems good first. could be a long thread this as theres to much to say in one go !
19-06-2007, 10:53 PM #12
It could be due to high discharge superheat if it is mounted on the compressor body. In many ac compressors the body is open to discharge pressure and temperature, this is why they often run very hot to the touch, this is done to use the compressor body as a discharge muffler to keep the noise down.
The manufacturer should be able to tell you what temperature it should switch at, you can then check this with an infra red thermometer. Maybe the thermal overload is faulty.
Cheers Jon
25-06-2007, 08:39 AM #13
thanks for the comments... was also wondering what is the name for the waxy stuff that motors are wound in,and any ideas what makes this stuff break down apart from moisture and heat,........
cheers
flow switch connection
By afeef in forum The Trail of TearsReplies: 18Last Post: 23-12-2009, 06:55 PM -
Low Pressure Cut-off switch on Liquid line
By Vishnukurup in forum Air ConditioningReplies: 14Last Post: 03-12-2008, 09:34 AM -
thermo acoustic refrigerator: problem with stack heating
By jackal in forum Technical DiscussionsReplies: 6Last Post: 04-09-2006, 05:03 PM -
Thermo King v? 00 MAX Tc Wiring Diagram
By Chris2005 in forum TransportReplies: 3Last Post: 01-02-2006, 08:01 AM -
shower switch fault !
By Krups in forum ElectricalReplies: 10Last Post: 19-10-2005, 09:10 PM
