Results 1 to 26 of 26
Thread: Calculating KW
    hookster's Avatar
    Apr 2007
    Hampshire
    438
    32
    Calculating KW
    If I have the tons/hour of a compressor how do I calculate the KW output of the compressor?
    Apr 2006
    1,620
    Re: Calculating KW
    hunt down a program called convert, it does every thing and is very usefull!
    Oct 2003
    5,630
    Re: Calculating KW
    Or Uconeer
    Feb 2007
    north west
    243
    Re: Calculating KW
    Oct 2005
    IRAN
    878
    Re: Calculating KW
    Hi there,
    TON means [BTU/hr] / 12000
    TONS /hr ????
    Also, TON or BTU/hr or kW can be converted to each other if they all represent thermal power. If you mean compressor electrical power (kW) then you can not convert thermal power to electrical one.
    Even Einstein Asked Questions
    May 2006
    India
    82
    1,013
    Re: Calculating KW
    3.420 kw ( Refrigeration Capacity ) = 1 Ton
    Oct 2005
    IRAN
    878
    Re: Calculating KW
    Quote Originally Posted by Samarjit Sen View Post
    hookster says TONS/HR ????
    May 2006
    India
    82
    1,013
    Re: Calculating KW
    Hookstar has got confused with BThu/hr and TR (Tons) He might be under the impression that Tons is also per hour.
    Aug 2005
    5,302
    Re: Calculating KW
    Ton-Hour is a valid term, but it is used more often in thermal storage than normal refrigeration systems.
    If you have a system with a 1 Ton capacity, that runs for 18 hours to maintain the temperature of some space, then you can say you have used 18 Ton-Hours to provide this cooling.
    This type of terminology is helpful when working with thermal storage systems. You need to know the total cooling load on a per hour basis for the entire time cycle (168 hours per week or 24 hours per day).
    You might consider this the total area under the curve for the load profile.
    May 2006
    India
    82
    1,013
    Re: Calculating KW
    Quote Originally Posted by hookster View Post
    Hello US Iceman,
    I agree to what you have said and described. But what do you think Hookster meant by the above statement.
    Oct 2005
    IRAN
    878
    Re: Calculating KW
    Hi everybody,
    [TON.hr] is energy but TON is power, i.e. energy/time.
    BUT he said TON/hr which I don't understand.
    Aug 2005
    5,302
    Re: Calculating KW
    My guess is he is talking about one of two things...
    1) he said kw output, which could imply heat rejection measured in kW.
    2) Or, he is looking for a conversion of Tons to kW(R) (refrigeration capacity in kW)
    It would help if he participated more in his own post???
    May 2006
    India
    82
    1,013
    Re: Calculating KW
    Good Morning US Iceman, one thing that I have noticed is that it is very seldom that the original member who put a thread participated in his posts. All members are eager to help, but without further details or clarifications it becomes difficult.
    Aug 2005
    5,302
    Re: Calculating KW
    ...it is very seldom that the original member who put a thread participated in his posts.
    Well there is that, but some may feel intimidated by all of us jumping into the discussion too I suppose. They really should not let that prevent them from participating.
    Oct 2003
    5,630
    Re: Calculating KW
    This is what I call basic politeness
    Alberto R.J.'s Avatar
    Alberto R.J. Guest
    Re: Calculating consumption
    Hello. I want to know the power consumption of a small refrigerator. the specification sheet says the power output is 320 watts. I know that the power input depends on the efficiency of the motor and other components, but being conservative, is there a factor that would let me know it?
    thanks
    alberto
    Oct 2003
    5,630
    Re: Calculating KW
    Devide the output with 2 tot 2.2 and you have +/- the input for a refrigerator.
    Jun 2007
    Sri Lanka
    88
    Re: Calculating KW
    Hi Dear Moderators & Members
    I would like to add my views to that of Samarjit, US Iceman & Peter_1. I have also noticed that the original person who put forward a post disappears after the first post. I hope you should address the original person along with the member you are giving suggestions counter suggestions which will encourage him to participating in the post.
    With in a very short period of time becoming a member I was able post more & more posts because members like Samarjit, Lana, GM Pony, Viking, Monkey Spanners, Shanman, and TXiceman to name few called me saying “Hi Suny”. That encourage me and therefore I feel I am not isolated in the form and you all recognize me.
    Even in this instance no body addressed hookster and you all were discussing the post among your selves, which isolated hookster. Therefore I would urge you all to address as Hi hookster & member’s name you want to address as an example even you quote his post.
    Please do not think that I have put you all learned moderators & members an embarrassing situation. This is my personal experience I have gained from this valuable forum. Hope you all agree to my suggestion positively. Thank you for reading this.
    Suny
    sankar's Avatar
    sankar Guest
    Re: Calculating KW
    what is the use of ecconomiser expansion valve. If it is not working ,what happend? Anyone can explain deeply.
    Oct 2003
    5,630
    Re: Calculating KW
    Sankar, this is a complete wrong post: wrong section, wrong time, replied on a post of 3 years old, not enough information.
    Nobody will read this..except me.
    vagee_arm's Avatar
    vagee_arm Guest
    Re: Calculating KW
    1ton=3.517kw
    1ton=0.02Btu/mim
    vagee_arm's Avatar
    vagee_arm Guest
    Re: Calculating KW
    1ton=3.517kw
    1ton=0.02Btu/min
  23. #23
    ruedarodante's Avatar
    ruedarodante Guest
    Re: Calculating KW
    How or where can I get the TECH Manual as check list?
  24. #24
    Oct 2003
    5,630
    Re: Calculating KW
    Ruedarodante, you're posting in a wrong section and replying with a new question.
    Where you can get this manual? Buy it from Gary.
    But it's not a checklist and you can't use it as a checklist neither.
  25. #25
    May 2008
    66
    802
    Re: Calculating KW
    hey Peter,
    it is fun to be stupid, let those boys play (LOL)
    Ice
  26. #26
    mohmmad ali's Avatar
    mohmmad ali Guest
    Re: Calculating KW
    i ,thank if comp.working 12 c to -15c
    1ton/h = 1kw/h in out put only.
  1. Calculating heat load
    By Abe in forum Technical Discussions
    Last Post: 13-08-2010, 05:40 PM
  2. Calculating heat load
    By Abe in forum Tools and Calculators
    Last Post: 25-03-2009, 10:29 AM
  3. Freeware for calculating coldroom capacity
    By Rosafung in forum Tools and Calculators
    Last Post: 07-12-2008, 01:34 PM
  4. Calculating refrigerant charge
    By Consultant in forum Refrigerants
    Last Post: 10-05-2005, 03:39 PM
  5. Calculating Cabinet Temperature?
    By mepgkyc in forum Trouble Shooting
    Last Post: 18-01-2002, 05:16 PM
