Results 1 to 19 of 19
Thread: Hiross PIN Code
    Oct 2005
    United Kingdom
    11
    Hiross PIN Code
    Does anybody happen to know the 3 charactor PIN code for the service level access on Liebert Hiross close control downflow units.
    I just need to reset the interval counters.
    Whisty
    Nov 2005
    Southampton
    45
    54
    Re: Hiross PIN Code
    try 221 - i think this is the code??
    cheers aeb
    Feb 2007
    2,473
    45
    Re: Hiross PIN Code
    That will work.
    Just be careful, with that code you are able to do a lot of damage.....
    Oct 2005
    United Kingdom
    11
    Re: Hiross PIN Code
    Thanks for the info but unfortunately the reason that I'm posting is because 221 doesn't work
    Apr 2006
    Torquay
    59
    130
    Re: Hiross PIN Code
    what about 805
    Nov 2005
    Ireland
    23
    Re: Hiross PIN Code
    You need a hiromatic controller connected to unit to reset the run hours
    Mar 2007
    France
    236
    Re: Hiross PIN Code
    Quote Originally Posted by Whisty View Post
    Hi, i've 2 Hiross under maintenance contrat.
    One is 221, the other 501, in setup menu they ask for 4 numbers, then try again 2210 or 5010 you'll access to level 2, search and put the counter to zero.
    My Hiromatics are E and H series
    Hope this helps
    rgds
    cool#9
    Mar 2005
    u.a.e
    68
    169
    Re: Hiross PIN Code
    try with 149 & 501
    malik55
    Mar 2007
    uk
    120
    Re: Hiross PIN Code
    Hi I also remember the code to be 501
    Feb 2008
    Wellingborough
    56
    35
    Re: Hiross PIN Code
    Quote Originally Posted by fintan View Post
    Correct. You cannot reset the run hours with the standard Microface display that is inside the unit, you do need a Hiromatic display (just to be clear, it is a display & not a controller).
    Nov 2005
    Ireland
    23
    Re: Hiross PIN Code
    Quote Originally Posted by Tiesse View Post
    The microface display in the unit is a LCD display. The Hiromatic is a controller as it is possible to control the functions of one or more Microface devices with it.
    Feb 2008
    Wellingborough
    56
    35
    Re: Hiross PIN Code
    Sorry, you are wrong. The lcd is a display that clips onto the Microface controller in most cases & the Hiromatic is a display that plugs into the Hirobus socket on the Microface, giving you a more user friendly interface into what the Microface is doing/set to.
    The Hiromatic also allows you to view & change settings of any units networked through the Hirobus connections.
    Aug 2008
    MALAYSIA
    44
    5
    Re: Hiross PIN Code
    Dear all
    Pls help...how to reset the controller hiross.i having alarm signal at red led,and the display show the triangle alarm but not show any massage.how to reset that..pls help..
    Aug 2010
    Jakarta
    57
    48
    Re: Hiross PIN Code
    Please help me...I'm looking for terminal remote shutdown at HIROSS HPM,can you show me were is the location?
    pwcpp's Avatar
    pwcpp Guest
    Re: Hiross PIN Code
    Just remove the bridge 020-366 (M66UA manufactured @2009) and then use a remote dry contact to control it.
    pwcpp's Avatar
    pwcpp Guest
    Re: Hiross PIN Code
    wiring diagram
    Aug 2010
    Jakarta
    57
    48
    Re: Hiross PIN Code
    Quote Originally Posted by pwcpp View Post
    Thank's a lot for your information,btw how about the terminal location for general alarm?
    bill84's Avatar
    bill84 Guest
    Re: Hiross PIN Code
    i think that the pass has four digits
  19. #19
    leeperrin's Avatar
    leeperrin Guest
    Re: Hiross PIN Code
    Hi All,
    I have followed this thread and i have a similar unit. I am trying to find out how to connect to it via a laptop for more control.
    Can anyone shed some light around this?
  1. Daikin secret's code, is it true? How?
    By cool#9 in forum Air Conditioning
    Last Post: 20-12-2007, 01:11 PM
  2. split a/c fault code
    By ksvinod in forum Air Conditioning
    Last Post: 04-07-2007, 02:12 PM
  3. HTML code fragment
    By Abe in forum Computers & the Internet
    Last Post: 22-03-2007, 05:07 PM
  4. Diplomat 6528 Fault Code
    By Targus in forum Domestic
    Last Post: 31-10-2006, 07:43 PM
  5. Fault Code Sheets...?
    By C_Henderson in forum Air Conditioning
    Last Post: 01-08-2006, 05:19 PM
