Results 1 to 8 of 8
    ardi's Avatar
    ardi Guest
    Thermobank system from Kramer
    Hi, I'm student/researcher in refrigeration engineering.
    I read about reverse cycle-hotgas defrost system from Kramer (Thermobank system), they use thermal storage to store the heat during refrig cycle (it acts as pre-condenser) and use it to re-evaporate the refrigerant during defrost cycle.
    In my opinion, this system have energy efficiency advantage as less heat wasted and no additional energy to defrost. It may have disadvantages as it needs additioal equipment e.g. thermal storage, valves and piping, and also pressure drop consideration.
    However, I think the benefit of energy efficiency is worth further investigation (use PCM, system efficiency etc.).
    My lack of experiences in real system works, causes me to ask this forum:
    Is this system have been widely applied?
    if no, are there any technical reason for not applying it?
    Are there any other advantage/disadvantages in this system?
    Thank you, I hope I can learn more on this forum
    Ardi
    India
    688
    Re: Thermobank system from Kramer
    I know carrier has been using this system even for their truck refer units. But the system is complicated in terms of expansion device & other controls. If I am correct Carrier is using Electronic exp device for this.
    Sometimes, without this reverse cycle, only hot gas is let in the evaporators & the liquid formed in the evaporator is then collected back in the receiver. ( again carrier does that)
    Feb 2004
    132
    There are 1000s of Kramer Thermobanks in the US. First one I serviced was in 1982. A pretty finiky system to setup, but once it's setup properly they work nice.
    Jan 2006
    Valrico, Florida
    509
    Quote Originally Posted by absrbrtek View Post
    We have approx. 20 Kramer units installed in Florida, if installed properly they work great!
    Aug 2005
    5,302
    I'll second that. The first ones I saw and worked on go back to the late 60's or 70's.
    Dec 2004
    United States
    I agree, if they are installed correctly they work well. The one reason that I know most do not use them is the long term maintenance required to keep them operating properly.
    Jan 2006
    Valrico, Florida
    509
    Quote Originally Posted by Capt Steve View Post
    The facility we have the Kramer units versus a plant of equal size running screws with Nh3 costs twice as much to maintain, not just parts but labor also.
    ardi's Avatar
    ardi Guest
    I see, so the main problem is system maintenance. For smpsmp45, thanks for your info, I plan to apply it in TRU. I didn't know Carrier have been using it. I hv checked their website and installation drawing but couldn't find the thermal storage and its installation. Could you give the model which use it? or maybe its spec.
    Thanks and regards,
    ardi
  1. Daikin fault codes
    By Chris2005 in forum Air Conditioning
    Last Post: 21-03-2012, 10:09 PM
  2. System Burn Out Troubleshooting
    By altaf22m in forum Technical Discussions
    Last Post: 07-05-2010, 09:24 AM
  3. Replies: 19
    Last Post: 15-04-2008, 07:03 PM
  4. Kramer Hot Gas, Thermobank
    By JAY BRANDELIK in forum New Technologies
    Last Post: 30-06-2003, 12:10 AM
  5. Refrigeration system proposal; comments please.
    Last Post: 01-01-2003, 03:42 PM
