    mjack's Avatar
    mjack Guest
    refridge diagnosic/monitoring equipment
    Does anyone know of good suppliers for on-line monitoring/diagnostic systems for refridge systems. I am referring to both temp/pressure diagnosics, need of charge detectors, leak detection, evaporator performance, amp monitoring etc.
    Thanks in advance, Mike
    Aug 2002
    Lancashire
    71
    8
    try contacting Danfoss, they have just introduced anew monitoring and management system for refrig systems
    Apr 2002
    Hamilton, Canada
    58
    been using microtherm for a couple of years now.
    www.microtherm.com
    Feb 2001
    Tampa Florida
    1,076
    I am getting my first exposure to NOVAR and Microtherm. I know they are both highly respected, as are many other utilities.
    But for now, I think CPC is easily the best control system around. Their user-interface through "Ultra-site" is as good as I have seen.
    Jan 2002
    Canada
    35
    Johson control has a large variety of on-line system, depending on the size of the building. Small system application for one freezers only up to entire plant facilities.
    Kathleen, P.eng
    www.refri-ozone.com
    Feb 2001
    Tampa Florida
    1,076
    We are doing our first Microtherm startup and my startup guy hates it! All the programming has to be done in an office 200 feet away from the compressor units.
    He says that any service tech who has to work on the equipment will have to bring a laptop with him. Can this be true? Also, I see that it is owned by Carrier.
  1. Equipment & Installation specifications
    By Kevin Yeo in forum Fundamentals
    Last Post: 14-01-2006, 10:36 AM
  2. Repossesing equipment.
    By Temprite in forum Air Conditioning
    Last Post: 08-09-2005, 09:58 PM
