    vinay's Avatar
    vinay Guest
    Question titanium and copper/brass/or stainless steel brazing?
    To all dear sirs,
    I am vinay here on this fantastic site for we the refrigeration professionals and i am very happy to know this site which is proving very much helpful for me these days.
    now we shall go to the following problem ,i am facing these days.
    could any one from you solve my problem of
    how to braze or weld the pure 'Titanium' and the copper or brass or even the stainless steel so that i would be able to fabricate the cooling coil for anodising application . the cooiling coil will be of titanium and all other refrigerant piping will be of copper.
    is there any other material other than the titanium for such an application i.e. for anodising application with respect of the H2SO4 ( sulphuric acid 20 % by volume )?
    expecting your reply
    have a nice time always.
    vinay
    vinay's Avatar
    vinay Guest
    Friends,
    Good Day
    It seems that no one is either interested or able to solve my small query
    I hope within few hours or say days I will get this brazing or welding done with the help of all of you.
    Till then Have a Nice Time,
    Eagerly waiting ,
    Vinay
    5,668
    Haven't really come across Titanium in the systems I work on - anyone else come across this?
    Apr 2002
    Pennsylvania, USA
    55
    78
    Unhappy NOPE, never seen this problem.
    I was unaware pure titanium was in use at all on refrigeration systems. I've dealt with heat exchangers with titanium coatings, but, fortunately for me, the connections were mechanical.
    Never lit a torch on it, although I'd imagine that 56% Silver solder would've done the job, but, again, that was only titanium COATED. (SS, I believe)
    Good luck with your search, vinay.
    Apr 2001
    Southern England
    66
    123
    Only fit for making planes!
    You will need an aerospace or oil (offshore) coded welding service. One of the local military airforce bases may have the equipment.
    Titanium has a problem with chlorine based refrigerants due to Stress Corrosion Cracking we know we tried it. Welding the stuff will mean a large investment in the tools. Braze is a no no as the fluid will eat it both your nasty stuff and the refrigerant due to the electrochemical activity.
    Copper to Titanium is also pretty bad on the electrochemical front. Frankly I's stick with 316L Stainless and have it stainless steel welded and then electrochemical stripped (not plated) to remove stress (corrosion) raisers. This is a process used by the offshore industry. As an alternative try Stainless with Swagelok couplings in 316 at least you will be able to replace bits as they fail. Monel metal is another option and Swagelok have that in their range but it costs arm, leg and wife plus small fortune.
    I seem to recall copper/copper electro tin plated coils were used for this sort of thing or was that just salt water........
    Derek
  1. Brazing vs. soldering
    By DaBit in forum Fundamentals
    Last Post: 19-03-2011, 11:50 AM
  2. Titanium BPHE
    By NoNickName in forum New Technologies
    Last Post: 10-06-2008, 04:51 AM
  3. Brazing Procedure Qualification
    By Delboy in forum Fundamentals
    Last Post: 18-12-2007, 07:04 AM
  4. Stainless steel insead of carbon steel
    By torque in forum Industrial
    Last Post: 23-09-2003, 09:45 PM
  5. Evaporators: Stainless Steel or Galvanized S.
    By Friobernal in forum Technical Discussions
    Last Post: 28-10-2002, 09:04 PM
